Count breakup events per cell
Old   February 5, 2015, 11:39
Post Count breakup events per cell
Andreas Weber
a.weber is on a distinguished road
Hello everyone,
I'm currently working on some changes on the sprayFoam solver to do different breakup and coalescence models.
It would be great to visualize areas of higher breakup/coalescence frequency. Therefore I create scalarfields (e.g. n_bu for breakup and n_coal) just as a counter for each cell. If breakup occurs in a cell, the value should just count up. Later on I could calculate the breakup freqeuncy easily with this field.
Breakup is mainly defined in
...../src/lagrangian/spray/parcels/Templates/SprayParcel/SprayParcel.C
What do I have to add there, to get my counter working?
Since SprayParcel.C is meant to only treat the particles fields, there is no direct access to the mesh fields (in some way read-only through interpolation of velocity Uc_ = td.UInterp().interpolate(....); )
The Idea is really easy, but I was not able to find a solution yet.
Best regards,
Andy
a.weber is offline   Reply With Quote
Old   February 5, 2015, 12:47
dkxls's Avatar
Armin
dkxls will become famous soon enough
Why would you want to get the breakup count per cell, why not per parcel?
Well, actually both could be quite interesting.
There is a unused "user" variable in the SprayParcel class. You could use that as a counter. The problem here is just that you determine the breakup event inside the BreakupModel classes, which don't have access to the "user" variable, or the mesh for that matter.
I'm not sure if it works, but you could try to pass the user variable to:
bool Foam::BreakupModel<CloudType>::update
This requires you to also change all breakup models, but that would be my best bet right now.
If you really start coding inside the SprayParcel template then you have access to the mesh. Can't remember where the mesh is kept, but I would probably check the KinematicParcel or KinematicCloud class first.
Once you have access to your fields you can also pass them to the breakup models and get your counter per cell.
I just saw that you have access to the cell number and TrackData already inside the void Foam::SprayParcel<ParcelType>::calcBreakup function.
You should get access to the mesh like this (haven't tested it though):
 const polyMesh& mesh = td.cloud().pMesh();
dkxls is offline   Reply With Quote
Old   February 9, 2015, 08:29
Andreas Weber
Using Breakup AND Coalescence Events together would end in a loss of information since one of the coalescing droplets/parcels will be deleted in the process.
Old   February 10, 2015, 08:43
Andreas Weber
Thank you for the quick reply!
I'm trying to define n_bu trough an IOobject, somehow like this:
volScalarField n_bu
IOobject
"n_bu",
td.cloud().db().time().timeName(),
td.cloud().db(),
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
But that wont work because I need the fvMesh to create an IOobject (but only have the polyMesh). I hope I've understood that right....
So I think what I have to do is to pass the fvMesh down to SprayParcel.C (e.g. from KinematicCloud.C).
Or is there a easier/faster solution to obtain the fvMesh???
Old   April 29, 2015, 05:56
Andreas Weber
Still haven't found a solution yet.
You're right so far, i can make use of
td.cloud().pMesh();
in
but so far I have only managed to get read-only access to the field values (e.g. to my counter-field "n_bu" with lookupObject<volScalarField>("n_bu")).
So is there a way to get write access somehow to that field, probably with a Pointer?
breakup model, coalescence, counter, particle
Cell Reynolds Number laliong Main CFD Forum 12 September 17, 2019 04:18
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
monitoring cell Jane Siemens 2 March 4, 2004 22:01
cell to cell relation CMB Siemens 1 December 4, 2003 05:05
