block coupled solver in 2.3.x
Old   February 3, 2015, 07:57
Default block coupled solver in 2.3.x
Peng Liang
tjliang is on a distinguished road
hello foamers,
i am now struggling with the conjunct heat transfer problem with chtmultiregionfoam. As in the fluid region a lot of equations need to be solved and at the moment the simulation is very unstable. And i was once advised by a nice foamer in our forum that to use a impilcit coupled solver in version 1.6.x, which will solve many equations simultaneously. But i have already worked with version 2.3.x for a long time. So i wonder if anyone could tell me if it's possible to have the same block coupled solver in 2.3.x. Otherwise i can only use very small time step with segregated solver to solve it which costs a lot of time.
Bests,
Peng
tjliang is offline   Reply With Quote
Old   February 4, 2015, 10:00
Henning86 is on a distinguished road
compiling a blocked-coupled solver from extended 3.1 in OF 2.3.x isn't straight forward at all. Its easier to start with extended 3.1.
you mentioned you had stabilty issues:
do you use fixedFluxPressure for the pressure boundary condition?
Henning86 is offline   Reply With Quote
Old   February 4, 2015, 13:59
Peng Liang
Hi, thank you for the reply. actually yes except for the outlet boundary. I mentioned this coupled solver is because i have a lot of equations to solve including two temperature equations and about 7 equations which describe the transport properties which are in turn also dependent from the two temperatures. So this set of many equations is actually coupled with each other. When i use segragated solver, namely chtmultiregionfoam, it's simply very hard to converge unless i use a time step of 1e-12s, it very time-demanding so i gave it up. For example when i have a temperature of 12000K in the last time step and i will get suddenly a temperature of ,say -2000000K, it's just very very unstable. I hope some one could offer me good suggestions, thanks.
Old   February 5, 2015, 05:48
block coupled solver are more effective with these equations.
in extended 3.1 there are some solvers which use the block coupled matrices.
Old   February 5, 2015, 10:31
Elvis
elvis will become famous soon enough
it makes sense to have multiple OF installations (ESI´s and OF-extend Project)side by side and just switch to that OF install by type "OF31ext" "OF231" or "OF23x" you can handle this by creating various/multiple "alias-scripts" in your $HOME/.bashrc-file.
"block coupled" can speed up things at the price of "bigger memory footprint" needed to handle bigger matrices.
comparison of segregated vs OF extend vs company optimised solver http://sourceforge.net/projects/open...W09_P_0037.pdf
elvis is offline   Reply With Quote
NASA Rotor 37 & Pressure-Based Coupled Solver Razvan FLUENT 6 June 11, 2015 04:58
Runge Kutta for (point-)implicit coupled compressible solver? Shenren_CN Main CFD Forum 0 October 15, 2012 04:12
segregated solver vrs coupled solver sm FLUENT 0 November 6, 2007 02:24
Can I use coupled solver for this problem Frank FLUENT 0 April 11, 2006 07:28
Coupled or Seggregated solver Ejaz Ahmed FLUENT 4 July 15, 2005 13:35
