understanding wmake
Old   January 11, 2015, 15:31
Default understanding wmake
thanasis is on a distinguished road
Dear all,
I am having difficulties in understanding how wmake works and how I can correctly compile an application to include subdirectories in the application folder.
I was experimenting using a rather simple example, which I named test_wmake utility. For this I employed the following file structure:
HTML Code:
Folder test_utility
    test_wmake.C
    -Folder Make
        -files
        -options
    -Folder Classes
        classA.H
        classA.C
        -Folder classB
            classB.H
            classB.C
The files were as follows:
test_wmake.C:
#include "fvCFD.H"
#include "Classes/classA.H"
int main(int argc, char *argv[])
    A A_(2.0);
    Info << A_.f(2.0) << endl;
    return 0;
Make/files:
test_wmake.C
Classes/classA.C
Classes/classB/classB.C
EXE = $(FOAM_USER_APPBIN)/test_wmake
Make/options:
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lgenericPatchFields
Classes/classA.H:
#ifndef CLASSA_H
#define CLASSA_H
#include "classB/classB.H"
namespace Foam
class A
    public:
        A(const double inX);
        ~A();
        double f(const double x) const;
    private:
        mutable B B_;
#endif // CLASSA_H
Classes/classA.C:
#include "classA.H"
namespace Foam
    A::A(const double inX) : B_(inX) {}
    A::~A() {}
    double A::f(const double x) const
        return B_.f(x);
Classes/classB/classB.H
#ifndef CLASSB_H
#define CLASSB_H
namespace Foam
class B
    public:
        B(const double inY);
        ~B();
    private:
        double y_;
#endif // CLASSB_H
Classes/classB/classB.C:
#include "classB.H"
namespace Foam
    B::B(const double inY) : y_(inY) {}
    B::~B() {}
    double B::f(const double x) const
        return x*y_;
when running wmake &> log, I get the following:
Making dependency list for source file test_wmake.C
could not open file classB/classB.H for source file test_wmake.C due to No such file or directory
Making dependency list for source file Classes/classA.C
Making dependency list for source file Classes/classB/classB.C
SOURCE=test_wmake.C ;  g++ -m64 -std=c++0x -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude  -IlnInclude -I. -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc++0xDPOpt/test_wmake.o
SOURCE=Classes/classA.C ;  g++ -m64 -std=c++0x -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude  -IlnInclude -I. -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc++0xDPOpt/classA.o
SOURCE=Classes/classB/classB.C ;  g++ -m64 -std=c++0x -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude  -IlnInclude -I. -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc++0xDPOpt/classB.o
g++ -m64 -std=c++0x -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude  -IlnInclude -I. -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64Gcc++0xDPOpt/test_wmake.o Make/linux64Gcc++0xDPOpt/classA.o Make/linux64Gcc++0xDPOpt/classB.o -L/home/thanasis/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc++0xDPOpt/lib \
         -lfiniteVolume -lgenericPatchFields -lOpenFOAM -ldl   -lm -o /home/thanasis/OpenFOAM/thanasis-2.3.x/platforms/linux64Gcc++0xDPOpt/bin/test_wmake
The application compiles correctly and when running test_wmake I get the correct answer. I do not understand though the very first error message "could not open file classB/classB.H for source file test_wmake.C due to No such file or directory" and how I can avoid this.
I am using openFoam 2.3.x which I compiled in ubuntru 14.04 using the Gcc++0x 4.8.2 compiler.
Any thoughts are mostly welcome!
thanasis is offline   Reply With Quote
subdirectories, wmake
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
