wmake problem: "sudo: wmake: command not found"
Old   January 11, 2015, 10:20
Exclamation wmake problem: "sudo: wmake: command not found"
Luis
Luiggito is on a distinguished road
I am a new user facing some problems:
I have a problem when I try to compile my solver, running wmake, it tells me:
I have openFOAM 2.1.1. I do modify my .bashrc to include the path to openFOAM's bashrc.
Do you know what can it be?. Thank you.
Luiggito is offline   Reply With Quote
Old   January 11, 2015, 14:48
Retired Super Moderator
Bruno Santos
Greetings Luis and welcome to the forum!
I know I've written about this quite a few times here on the forum, and here are a few links to what I've written in the past:
  • http://www.cfd-online.com/Forums/blo...ml#comment1682
  • Quote:
    Originally Posted by wyldckat View Post
    You're building as "root", namely with administrative powers. This is dangerous as one wrong step is more than enough to damage your system installation and have to reinstall everything again if something critical is damaged. My guess is that you missed the step #4 which explicitly states that you should run the command "exit" before proceeding, as this will exit from root mode .
Beyond this, please provide more context to what exactly you're trying to do.
Best regards,
Bruno
command not found, compile, solver, wmake
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
missing vtf3.h BPatch.h papi.h linch OpenFOAM Installation 41 July 24, 2012 15:45
wmake error zxj160 OpenFOAM 0 March 26, 2012 11:52
