janaf dynamic_cast issue
Old   January 7, 2015, 11:13
Default janaf dynamic_cast issue
sebastien vilfayeau
sebastien_F1 is on a distinguished road
I'm working on fireFoam and I try to implement a new model. For this model, I need to have access to polynomial Janaf coefficients defined in "constant/thermo.compressibleGas".
My solution was to use a dynamic_cast inside my code as follows :
    // Setup the janaf thermo class
       typedef janafThermo<perfectGas<specie> > janafType;
         typedef sutherlandTransport<sensibleEnthalpy<janafType> > thermoType;
         const multiComponentMixture<thermoType>& myThermo =
         dynamic_cast<const multiComponentMixture<thermoType>&>(this->thermoPtr_());
    // O2 thermal enthalpy
        // Oxygen label
         const label specie_O2 = this->thermoPtr_->composition().species()["O2"];
        // Compute janaf class for O2
         const janafType& myThermo_O2 = dynamic_cast<const janafType&>(myThermo.speciesData()[specie_O2]);
        // Compute molecular thermal enthalpy [J/kmol]
        scalar H_O2 = myThermo_O2.hs(1e5, Tair_);
        // Compute molecular weight [kg/kmol]
        scalar MW_O2 =  this->thermoPtr_->composition().W(specie_O2);
        // Calculate thermal enthalpy [J/kg]
        scalar hs_O2 = H_O2/MW_O2;
        Info << "hs_O2 = " << hs_O2 << endl;
It was working fine in OpenFOAM.2.1 but in OpenFOAM.2.2, I have the following error:
cannot dynamic_cast ... (source type is not polymorphic)
Anyone has a hint how to solve this problem?
Thanks
Sebastien
sebastien_F1 is offline   Reply With Quote
how can see Cp values? immortality OpenFOAM Post-Processing 51 June 18, 2021 08:19
Entropy calculation in OpenFoam immortality OpenFOAM 23 September 8, 2013 18:18
Strange issue while launching ANSYS workbench in CentOS 6.4 Philip_C ANSYS 11 August 29, 2013 07:44
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 03:00
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 09:27
