refCast compilation and understanding error
Old   December 17, 2014, 06:03
Default refCast compilation and understanding error
Martin K
Martin_K_lalelu is on a distinguished road
Hi all,
while trying to move a mesh by modifying the pointDisplacement file out of my solver, I got stuck. I could really need some help using and understanding refCast.
Here is what I got:
    pointVectorField& PointDisplacement = refCast<pointVectorField&>
        mesh.objectRegistry::lookupObject<pointVectorField>
        "pointDisplacement"
     vectorField& pDisp = PointDisplacement.internalField();
    vectorField& pDispOld = pDisp;
     pDisp == vector (0,0,0.001)+pDispOld;
The corresponding compilation error:
/home/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/typeInfo.H: In instantiation of ‘To& Foam::refCast(From&) [with To = Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>&; From = const Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>]’:
../pointDisplacementInterFace.H:15:2:   required from here
/home/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/typeInfo.H:110:35: error: cannot dynamic_cast ‘r’ (of type ‘const class Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>’) to type ‘class Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>&’ (conversion casts away constness)
         return dynamic_cast<To&>(r);
/home/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/typeInfo.H:116:28: error: ‘typeName’ is not a member of ‘Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>&’
             << " to type " << To::typeName
/home/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/typeInfo.H:119:35: error: cannot dynamic_cast ‘r’ (of type ‘const class Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>’) to type ‘class Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>&’ (conversion casts away constness)
/home/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/typeInfo.H: In function ‘To& Foam::refCast(From&) [with To = Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>&; From = const Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>]’:
/home/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/typeInfo.H:121:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64GccDPOpt/myInterDyMFoam.o] Fehler 1
Martin_K_lalelu is offline   Reply With Quote
Old   April 26, 2018, 20:14
Scram_1 is on a distinguished road
Hey,
I'm getting the same error. Did you manage to figure it out?
Best,
Scram_1
Scram_1 is offline   Reply With Quote
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
fireFoam.1.7.x_0.4 compilation error !link OpenFOAM Installation 9 December 24, 2012 05:15
