How to locate this bug?
Old   December 13, 2014, 23:49
Default How to locate this bug?
BO WANG
wang219910611 is on a distinguished road
Hi everyone,
While I am trying to test my own solver on a new case, following error appears:
Reading transportProperties
--> FOAM FATAL ERROR:
LHS and RHS of - have different dimensions
     dimensions : [0 0 0 0 0 0 0] - [1 -1 -1 0 0 0 0]
    From function operator-(const dimensionSet&, const dimensionSet&)
    in file dimensionSet/dimensionSet.C at line 499.
FOAM aborting
with the help of the info statement, I believe the error should be somewhere in the following code, which is in the creatField.H file :
Info<< "Reading transportProperties\n" << endl;
    incompressibleTwoPhaseMixture twoPhaseProperties(U, phi/*, "Ybar"*/);
    const dimensionedScalar& rho1 = twoPhaseProperties.rho1();
    Info<< "Done Reading transportProperties\n" << endl;
The strange part is that I can't find any "-" in the above code or in the incompressibleTwoPhaseMixture file ( they are the original ones ). Any clues where can I locate this error?
Many thanks. : )
wang219910611 is offline   Reply With Quote
Old   December 14, 2014, 04:51
Retired Super Moderator
Bruno Santos
Greetings wang219910611,
My advice is to make sure that you're debugging the correct lines. Change that piece of code to this:
Info<< "Got here 00" << endl;
Info<< "Got here 01" << endl;
Info<< "Got here 02" << endl;
Why am I suggesting this? Because there might be more than one piece of code that gives the output "Reading transportProperties", and in addition, it will give a clearer notion of where exactly the problem is located.
The other suggestion is to look at the dictionary files that are loaded by this piece of code. My guess is that there isn't only one file and that a bug might be present in any of those dictionary files.
Beyond this: http://openfoamwiki.net/index.php/HowTo_debugging
Best regards,
Bruno
Old   December 18, 2014, 04:34
BO
xianqiejiao is on a distinguished road
Hi Bruno, sorry for the late reply. I turned back to learn more about gdb and c++ these days, trying to fix the bug.
I think I have managed to locate the bugs to my visThermo. This is a new thermo type I tried to set up by copying the way of psiThermo. Here is what I got from gdb:
Program received signal SIGSEGV, Segmentation fault.
0x00000000005219d8 in Foam::HashTable<Foam::autoPtr<Foam::visThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash>::find (
    this=0x0, key=...)
    at /home/bo/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/HashTable.C:143
143        if (nElmts_)
(gdb) frame 0
#0  0x00000000005219d8 in Foam::HashTable<Foam::autoPtr<Foam::visThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash>::find (
    this=0x0, key=...)
143        if (nElmts_)
(gdb) frane 1
Undefined command: "frane".  Try "help".
(gdb) frame 1
#1  0x0000000000520ef0 in Foam::basicThermo::lookupThermo<Foam::visThermo, Foam::HashTable<Foam::autoPtr<Foam::visThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash> > (thermoDict=..., tablePtr=0x0)
    at /home/bo/OpenFOAM/OpenFOAM-2.3.0/src/thermophysicalModels/basic/lnInclude/basicThermoTemplates.C:68
68            typename Table::iterator cstrIter = tablePtr->find(thermoTypeName);
I have attached the visThermo file in the attachment. I think I have copied most of the line from psiThermo except the last few ones, which are member function. In my visThermo, I have got Ybar ( phase density), rho, mu1 for phase 1, mu2 for phase 2 and mu. Should I set the member functions in visThermo like the following ?
  virtual const volScalarField& Ybar() const;
            virtual const scalarField& Ybar(const label patchi) const;
            virtual tmp<volScalarField> rho() const
            virtual tmp<scalarField> rho(const label patchi) const;
            virtual volScalarField& rho();
            virtual const scalarField& mu1 const;
            virtual const scalarField& mu2 const;
            virtual const volScalarField& mu() const;
            virtual const scalarField& mu(const label patchi) const;
xianqiejiao is offline   Reply With Quote
dieselEngineFoam bug - OpenFOAM-1.6-ext novakm OpenFOAM Bugs 1 December 5, 2013 14:18
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 09:15
a cone injection,please help me!! satum FLUENT 0 July 2, 2008 03:38
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 11:05
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 11:22
