operator for creating squared components of a tensor
Old   December 8, 2014, 09:45
Question operator for creating squared components of a tensor
Blaž Mikuž
bmikuz is on a distinguished road
Hi!
I need a simple operator which works on a tensor and calculates another tensor with squared components (a_{ij} -> (a_{ij})^2). Is there already an operator, which does that in OF?
I've tried an outer product (gradU*gradU):
tmp<volTensorField> S2(const tmp<volTensorField>& gradU) const
        return (gradU * gradU);
but it seems not to be defined on tensors since compiling produces:
error: no match for ‘operator*’ in ‘gradU * gradU’
Than I tried also sqr(gradU), but compiling says
error: no matching function for call to ‘sqr(const Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >&)’
Any help would be appreciated. THX!
Blaz
bmikuz is offline   Reply With Quote
Old   December 10, 2014, 11:24
Blaž Mikuž
I may not be clear enough. I need to create a new volTensorField, which tensor's elements are squared tensor elements of gradU field (gradU is also a volTensorField typedef):
PHP Code:
gradU[cellI] =  ( abcdefgh
newTensor[cellI] = ( a^2b^2c^2d^2e^2f^2g^2h^2i^
Now, I realized that there is no existent operation on volTensorField, which could directly produce such a result.
So, my idea is to define a new operation among volTensorField objects, which would directly produce required new volTensorField. Is this easy to implement or not? What do you suggest?
Thanks!
Blaz
Old   January 10, 2019, 07:56
gu1
Guilherme
gu1 is on a distinguished road
PHP Code:
Thanks!
Blaz
Is this possible to do?
gu1 is offline   Reply With Quote
Old   January 13, 2019, 23:09
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
cmptMultiply(gradU,gradU)?
https://openfoam.top
zhangyan is offline   Reply With Quote
component, operator, square, tensor
Stress tensor components ap FLUENT 1 August 15, 2023 04:41
tensor components LM4112 OpenFOAM Post-Processing 0 June 17, 2013 12:02
Accessing the components of the resolved Reynolds stress tensor in a LES flotus1 FLUENT 8 January 21, 2013 04:34
Problems compiling with the 'diag' tensor function (diagonal components matrix) danihuso OpenFOAM Programming & Development 12 January 31, 2012 11:45
Strain-rate tensor components vkrastev OpenFOAM 2 March 2, 2010 03:39
