Anurag
Rep Power: 12 ![]() |
Hi everyone
I made some changes to a solver and while trying to compile it, I get the following error. The solver I am modifying is multiphaseEulerFoam. I have posted the exact changes in this thread. Code:
+ wmakeLnInclude interfacialModels wmakeLnInclude: linking include files to interfacialModels/lnInclude + wmake libso multiphaseSystem wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file phaseModel/phaseModel.C Making dependency list for source file diameterModels/diameterModel/diameterModel.C Making dependency list for source file diameterModels/diameterModel/newDiameterModel.C Making dependency list for source file diameterModels/constantDiameter/constantDiameter.C Making dependency list for source file diameterModels/isothermalDiameter/isothermalDiameter.C Making dependency list for source file alphaContactAngle/alphaContactAngleFvPatchScalarField.C Making dependency list for source file multiphaseSystem.C SOURCE=phaseModel/phaseModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I../phaseModel/lnInclude -I../interfacialModels/lnInclude -IalphaContactAngle -I/home/misra/OpenFOAM/OpenFOAM-2.1.1/src/transportModels -I/home/misra/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/incompressible/lnInclude -I/home/misra/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/interfaceProperties/lnInclude -I/home/misra/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/phaseModel.o In file included from /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.H:360:0, from /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/DimensionedField.H:42, from /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/GeometricField.H:44, from /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/volFields.H:37, from phaseModel/phaseModel.H:38, from phaseModel/phaseModel.C:26: /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C: In member function ‘void Foam::Field<Type>::operator=(const Foam::VectorSpace<Form, Cmpt, nCmpt>&)’: /home/misra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Field.C:680:42: warning: typedef ‘VSType’ locally defined but not used [-Wunused-local-typedefs] typedef VectorSpace<Form,Cmpt,nCmpt> VSType; ^ phaseModel/phaseModel.C: In constructor ‘Foam::phaseModel::phaseModel(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)’: phaseModel/phaseModel.C:46:13: error: ‘groupName’ is not a member of ‘Foam::IOobject’ IOobject::groupName("alpha", phaseName), ^ phaseModel/phaseModel.C:84:13: error: ‘groupName’ is not a member of ‘Foam::IOobject’ IOobject::groupName("U", phaseName), ^ phaseModel/phaseModel.C:96:13: error: ‘groupName’ is not a member of ‘Foam::IOobject’ IOobject::groupName("DDtU", phaseName), ^ phaseModel/phaseModel.C:107:13: error: ‘groupName’ is not a member of ‘Foam::IOobject’ IOobject::groupName("phiAlpha", phaseName), ^ phaseModel/phaseModel.C:115:26: error: ‘groupName’ is not a member of ‘Foam::IOobject’ const word phiName = IOobject::groupName("phi", name_); ^ make: *** [Make/linux64GccDPOpt/phaseModel.o] Error 1 |
in 2.1.1 there's no IOobject::groupName method in IOobject class (basically what the error tells you). Here's code from 2.3.0: Code:
template<class Name> inline Foam::word Foam::IOobject::groupName(Name name, const word& group) { if (group != word::null) { return name + ('.' + group); } else { return name; } } Code:
IOobject::groupName("alpha", phaseName) Code:
"alpha" + ('.' + phaseName) |
Anurag
Hi Alexey,
Thanks for the reply. I dont understand how it could be a problem with the definition of classes because this is a standard OpenFOAM solver. I just modified it to use RAS (k-epsilon) model instead of LES. No other changes were made. Do you think it could be because of a missing library in the Make/files ? I will try your solution as well to see if that works. Regards, Anurag |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Error while compiling modified icoFoam: "cannot find lthermophysicalModels" | DuarteMagalhaes | OpenFOAM Running, Solving & CFD | 6 | June 15, 2014 14:03 |
Problem with compiling new solver | palazi88 | OpenFOAM Programming & Development | 2 | December 24, 2013 19:52 |
Error while compiling solver | umar82088 | OpenFOAM Programming & Development | 3 | July 8, 2013 02:23 |
Error in compiling a modified solver | immortality | OpenFOAM Running, Solving & CFD | 3 | March 29, 2013 00:29 |
