modified solver gives this message: "incompatible dimensions for operation" |
October 30, 2014, 07:18 |
sajad
Rep Power: 12 |
I add enetgy equation to icoFoam and build icoHeatFoam. after I make blockMesh and boundrycondition I face with this error:
ajad@sajad-pc:~/Desktop/heatedCavity$ icoHeatFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : icoHeatFoam Date : Oct 30 2014 Time : 14:44:14 Host : "sajad-pc" PID : 5810 Case : /home/sajad/Desktop/heatedCavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field T Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0.0001875 max: 0.005 --> FOAM FATAL ERROR: incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] == [-grad(p)[1 -2 -2 0 0 0 0] ] From function checkMethod(const fvMatrix<Type>&, const GeometricField<Type, fvPatchField, volMesh>&) in file /opt/openfoam210/src/finiteVolume/lnInclude/fvMatrix.C at line 1337. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 in "/home/sajad/OpenFOAM/sajad-2.1.0/platforms/linuxGccDPOpt/bin/icoHeatFoam" #3 in "/home/sajad/OpenFOAM/sajad-2.1.0/platforms/linuxGccDPOpt/bin/icoHeatFoam" #4 in "/home/sajad/OpenFOAM/sajad-2.1.0/platforms/linuxGccDPOpt/bin/icoHeatFoam" #5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #6 in "/home/sajad/OpenFOAM/sajad-2.1.0/platforms/linuxGccDPOpt/bin/icoHeatFoam" Aborted tnx for any help(I attached my case) Last edited by wyldckat; November 1, 2014 at 15:41. Reason: Added [CODE][/CODE] |
October 30, 2014, 07:22 |
Yogesh Bapat
Rep Power: 16 |
As given in error message this is due to dimension mismatch " incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] == [-grad(p)[1 -2 -2 0 0 0 0] ]". Dimensions on both side of == operator should match. Regards, -Yogesh |
October 30, 2014, 07:31 |
sajad
Rep Power: 12 |
I corrected it.
but after that I faced with this error: Code:
sajad@sajad-pc:~/Desktop/heatedCavity$ icoHeatFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : icoHeatFoam Date : Oct 30 2014 Time : 15:03:54 Host : "sajad-pc" PID : 6130 Case : /home/sajad/Desktop/heatedCavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field T Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0.0001875 max: 0.005 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 5.92928e-10, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 1.47998e-08, No Iterations 4 --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 0.00059703 Specified mass inflow : 0.06 Specified mass outflow : 0 Adjustable mass outflow : 1.08799e-70 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. FOAM exiting Last edited by wyldckat; November 1, 2014 at 15:42. Reason: Added [CODE][/CODE] |
October 30, 2014, 08:02 |
anonymous
Rep Power: 13 |
With out your case and your BC we can do little.
Are you sure or scalar equation is right implemented? |
Error message in Solver | Sara | CFX | 8 | November 8, 2019 05:35 |
Solver error message - memory usage | Jared1986 | CFX | 12 | December 2, 2014 06:28 |
solver error message | Jared1986 | CFX | 1 | May 14, 2014 15:32 |
Incompatible dimensions.... | Amiga500 | OpenFOAM Running, Solving & CFD | 13 | June 1, 2012 08:20 |
Error message | Pandu Sattvika | CFX | 0 | March 1, 2002 16:28 |
