Solving 1D-equation on each patch face
Old   October 20, 2014, 07:45
Default Solving 1D-equation on each patch face
chriss85 will become famous soon enough
I would like to solve a one-dimensional transient heat conduction equation on each patch face of a boundary.
What kind of approach is best suited for this?
1) Extruding each patch face in a new mesh on which the equation is solved, using empty boundaries at the sides?
2) Manually discretizing the equation and write my own solver algorithm?
3) I think I also read in one of the later release notes about ODE-solving capabilities, but I haven't investigated this yet (will do once I find some time).
Does anyone know of a similar use case with a reference implementation that I could use as a template?
chriss85 is offline   Reply With Quote
Old   October 23, 2014, 10:25
I made some progress on this and wanted to share it.
OpenFOAM already contains a very nice tool for creating 1d-extruded meshes from a boundary, called extrudeToRegionMesh. Using this, it is possible to create separate meshes with 1d-extrusions which can be coupled to the primary mesh (see chtMultiRegionFoam as an example).
I haven't done the programming yet, but I'm very confident this will work just like I need it.
Old   October 13, 2016, 04:51
giack is on a distinguished road
Hi Crhiss,
let's see if I understood it properly: with extrudeToRegionMesh it is possible to create a mesh from a boundary, map the variables in the new mesh and run on that a 1D solver. Am I right?
I'm trying to figure out how to solve an implicit equation on a boundary and this method could help.
Regards
giack is offline   Reply With Quote
Old   October 13, 2016, 05:34
It creades a new region containing extruded cells where you can choose if they are 1D for each boundary face or connected to each other IIRC. You can then use this mesh and solve equations on it. It's also possible to couple it using the appropriate boundary conditions. Keep in mind that the coupling is done in a segregrated approach, meaning you need to solve the equations on the meshes separately, possibly in a loop.
Old   October 14, 2016, 12:26
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Do you know how can I transform them into a coupled system?
Zeppo is offline   Reply With Quote
Old   October 14, 2016, 16:44
Ehimen
Elliptic CFD is on a distinguished road
Please, could you give the steps on how this is done. For my project, I want to extrude a mesh from the wall boundary into the fluid region. Hence, a 1D code will be used for the embedded mesh to calculate wall shear stress fields that will feed into the main mesh.
If I can get the extrudeToRegionMesh utility to work properly, I could use it to create embedded meshes for more complex geometries than channel flow
Elliptic CFD is offline   Reply With Quote
Old   October 17, 2016, 06:05
Check the example dictionary in the tools directory (applications/utilities/mesh/generation/extrude/extrudeToRegionMesh) for the possible options you can use with this tool. In the end it will generate a new mesh as a separate region, so your solver will need to be able to work with multiple regions in a case. You will probably also need some kind of mapped boundary condition. On the extruded case you can solve equations in the same way as you would on a single mesh.
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
