October 16, 2014, 02:51 |
chtMultiRegion + Adaptive Mesh Refinement
Robert mellema
Rep Power: 12 |
Hi all,
I have been working with some modified chtMultiRegion codes for the simulation of crystal growth process. Right now, I am trying to implement Adaptive Mesh Refinement (AMR) from pimpleDymFoam into the modified chtMultiRegionFoam with no success. I have implemented the AMR successfully into the fluid only solver. However, when I combine it with the conjugate heat solver (chtMultiRegion), due to the difference in the mesh name (fluidRegions in chtMultiregion) I could not do the mesh update. Would you please guide me how I can make the solver? Best regards, Robert |
February 8, 2016, 15:40 |
Peng Liang
Rep Power: 12 |
Hello Robert,
I have now the same problem, have you already solved that? I will be grateful if you would offer me any hints. Best Regards , Peng |
February 21, 2022, 03:16 |
adaptive mesh
Rep Power: 6 |
Hello, any updates? Have you guys succeeded?
Mike |
Adding adaptive mesh refinement to the forwardStep tutorial | AlphaSheep | OpenFOAM Running, Solving & CFD | 10 | August 3, 2019 15:40 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Adaptive Local Mesh Refinement | Abhishekd18 | OpenFOAM Running, Solving & CFD | 26 | March 31, 2015 09:19 |
[snappyHexMesh] Propeller mesh not smooth | nortanapura | OpenFOAM Meshing & Mesh Conversion | 0 | May 16, 2014 04:26 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 18:12 |
