My FSI simulation (pipe-flow)
Old   September 24, 2014, 18:24
Default My FSI simulation (pipe-flow)
Tommy Sp
vitorspadeto is on a distinguished road
This is my simulation using FSI. See the files in this link to download it:
http://www.filedropper.com/pipe
I used the solver inside EXTEND-BAZAAR (foam-extend) to FSI simulation. See the directory:
Screenshot from 2014-09-24 18:15:21.jpg
I used this case (3Dtube) to create my simulation. But the result was not as expected.
The deformation of the tube (due to the pressure of the pulsatile flow) should be higher. The deformation of the tube was approximately 0.01cm as should be of the order of 1cm. One could look at the files and try to find where is the error?
*I consider the fluid with viscosity of 0.0035Pa.s divided by 1050kg/m³ (density of the flow) = 0.0000033333333 m²/seconds
there in the archive( http://www.filedropper.com/pipe ) a pdf document that explains the conditions and parameters that I wanted to use in my simulation. you must read it initially. Unfortunately the compressed file you download need to change, "solid" link in the fluid/constant directory and "fluid" link in the solid/constant directory must be recreated because they became a folder in the process of .zip compression...
Best Regards,
Vitor Spadeto
vitorspadeto is offline   Reply With Quote
Old   September 24, 2014, 18:27
Tommy Sp
sorry for posting in this area, but I believe that in other areas of the forum no one will know answer....
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Vertical Pipe water flow Goutam FLUENT 0 April 30, 2014 09:25
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 12:46
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
FDTD Simulation of flow through tapered pipe Jim Main CFD Forum 3 December 25, 2006 11:56
