corrupted double-linked list
Old   September 16, 2014, 11:06
Default corrupted double-linked list
Will
willzyba is on a distinguished road
Can anyone help me to understand why I get this error.
*** glibc detected *** waveFoamLPT: corrupted double-linked list: 0x0000000000c02a50 ***
I've joined Lagrangian Particle Tracking with classical volume of fluid method. Our solution actually runs very nicely and produces the results we expect, but when the program finished and is closing down we get this error.
I've tried recompiling all of OpenFOAM incase I had some old out of date library. We've also tried this on another comptuer, with a similar setup.
What we've essentially done now, is copy our working copy of WaveFoam (which is really just icoFoam)
and added to the Make/options these two line
    -llagrangian \
    -lsolidParticle
giving us
EXE_INC = \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
    -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/fvOptions/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -DOFVERSION=220 \
    -DEXTBRANCH=0 \
    -DXVERSION=$(WAVES_XVERSION) \
    -I$(WAVES_SRC)/waves2Foam/lnInclude \
    -I$(WAVES_SRC)/waves2FoamSampling/lnInclude \
    -I$(LIB_SRC)/lagrangian/basic/lnInclude
EXE_LIBS = \
    -limmiscibleIncompressibleTwoPhaseMixture \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -L$(WAVES_LIBBIN) \
    -lwaves2Foam \
    -lwaves2FoamSampling \
    -llagrangian \
    -lsolidParticle
After a lot of experimentation, it appear this arises as soon as I link to
    -llagrangian \
    -lsolidParticle
We have changed nothing else in the code.
Will
willzyba is offline   Reply With Quote
Old   September 18, 2014, 13:15
Default Soved
Will
Linking with -lsolidParticle caused this.
As we were replacing many of the functionality in solidParticle with out own, then I guess the final executable ended up with two versions of similar code. For some reason this got through linking, but crashed the program on exit.
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 04:34
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 07:09
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
