Problem obtaining alphaTurbulent in pisoFoam
Old   August 8, 2014, 11:17
Default Problem obtaining alphaTurbulent in pisoFoam
anonymous
ssss is on a distinguished road
I've implemented a scalar Transport equation to pisoFoam, but I cannot obtain some values from it
Let's start with it:
In createFields.H I add the following:
Info<< "Reading field alphaT\n" << endl;
volScalarField alphaT
    IOobject
            "alphaT",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
dimensionedScalar prandtlTurbulent(laminarTransport.lookup("prandtlTurbulent"));
singlePhaseTransportModel laminarTransport(U, phi);
    autoPtr<incompressible::turbulenceModel> turbulence
        incompressible::turbulenceModel::New(U, phi, laminarTransport)
In my_pisoFoam.C
#include "turbulenceModel.H"
#include "createFields.H"
int main(){
        alphaT=turbulence->nut()/prandtlTurbulent;
        alphaT.correctBoundaryConditions();
In 0/alphaT
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alphaT;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated; //search for it
        //value           uniform 0;
    outlet
        //value           uniform 0;
    channelWall
        type            zeroGradient;
    symmetry
        type            symmetryPlane;
    frontAndBack
        type            empty;
In constant/transportProperties
prandtlTurbulent prandtlTurbulent [0 0 0 0 0 0 0] 0.85;
But whenever I open alphaT in every folderIteration I only see:
FoamFile
    version     2.0;
    format      ascii;
    location    "0.003";
    object      alphaT;
boundaryField
    channelWall
        type            zeroGradient;
    symmetry
        type            symmetryPlane;
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    frontAndBack
        type            empty;
It only repeats the alphaT which is in 0/ . It doesn write anything.
Maybe it is because I choose this?
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      RASProperties;
RASModel        laminar;
turbulence      on;
printCoeffs     on;
RASModel = laminar.
Thank you very much.
ssss is offline   Reply With Quote
Old   August 10, 2014, 04:36
anonymous
I found the problem, if I choose the turbulence as laminar, he would assume that nut is 0. I will try to see how could I make a dns simulation with pisoFoam and then get nut somewhere
Thank you
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Problem in implementing cht tilek CFX 3 May 8, 2011 09:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
