Implicit handling of sources which couple components using Vector-Coupled Solver |
July 20, 2014, 06:50 |
Fumiya Nozaki
Rep Power: 19 |
I found it says in the release note of v2.2.0(http://www.openfoam.org/version2.2.0/matrix-solvers.php) that "The block-matrix structure can also be used to support implicit handling of sources which couple components, e.g. SRF, MRF, etc. although this requires some changes to the respective applications." I think it means that we can use this functionality to handle the Coriolis force implicitly. Could you tell me what kind of changes do I have to make in SRFSimpleFoam? I'll welcome any comments from you. Best regards, Fumiya
[Personal]
September 22, 2014, 04:42 |
I would like this to happen, too ;-)
Kim Ravn-Jensen
Rep Power: 13 |
Fumiya,
I would so much have liked to be able to give you a useful reply. I believe that my tet-mesh (from CFX-Pre) of a real-world, commercial geometry contributes to my problem: Slowly through a series of more than hundred iterations, one single cell may develop an unphysically large velocity where zero would be the velocity to expect. Then I thought that I should look for a game-changer, imagined that implicit solving for the Coriolis force might be one, and yesterday I found your posting. Have you made any progress since then? Does, by chance, anybody have a solution to my problem? Best regards, Kim |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
mulitphase model that works with implicit solver? | rabaeto | FLUENT | 0 | August 9, 2005 12:53 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
FD NS implicit solver | N.SUBRAMANIAN | Main CFD Forum | 6 | August 20, 2000 23:24 |
