rhoReactinBuoyantFoam - Buoyant Mixing of two gases
Old   July 13, 2014, 14:09
Default rhoReactinBuoyantFoam - Buoyant Mixing of two gases
Krishna
rkc.cfd is on a distinguished road
I am trying to implement mixing of buoyant turbulent helium jet with ambient air. I have taken rhoReactingBuoyantFoam and dropped the eEeqn as I am doing an iso Thermal jet. I switched of both chemistry and combustion.
The velocity is dissipating immediately after the entrance and its quite strange and dont know to address this issue.
My Thermo settings are
thermoType
    type            heRhoThermo;
    mixture         multiComponentMixture;
    transport       const;
    thermo          hConst;
    energy          sensibleInternalEnergy;
    equationOfState incompressiblePerfectGas;
    specie          specie;
My LES settings are
LESModel        Smagorinsky;
turbulence      on;
printCoeffs     on;
delta           cubeRootVol;
cubeRootVolCoeffs
    deltaCoeff      1;
  SmagorinskyCoeffs
      filter simple;
      ce 1.048;
The domain I am simulating is simple cylinder connected to the a box.
The mesh is coarse to check the running of the simulation at 1.7M cells.
Attached are also the boundary conditions and schemes used.
0.tar.gz
system.tar.gz
Hope somebody can provide some suggestions to find the issue of the velocity dissipating immediately after the inlet.
Cheers
rkc.cfd is offline   Reply With Quote
mixing gases, rhoreactinbuoyantfoam
2D simulation for mixing two non-reacting gases arun.mechie FLUENT 17 August 3, 2016 09:31
2 gases mixing flow pipin FLUENT 0 April 15, 2011 12:14
Mixing of two non-reacting gases vishyaroon Main CFD Forum 2 August 6, 2009 10:26
solve the mixing of gases Prashant FLUENT 4 May 21, 2008 01:51
Floworks: Mixing and thermal analysis of two gases Jay Nelson Main CFD Forum 0 June 14, 2005 19:29
