Temperature gradient for the internal Field.
Old   July 2, 2014, 04:15
Default Temperature gradient for the internal Field.
Philipp Dietrich is on a distinguished road
I am currently trying to add a heat source to the icoFoam solver.
The heat source will be dependent on the Temperature gradient in a specific direction. Therefore I have to access the temperature gradient of each cell.
I tried to use the "fvc::grad(T)" to define a new volVectorField for the gradient.
However, it seems, that especially in the cells at a boundary this gradient is not calculated right. (nonzero temperature gradient at "empty" boundary; unphysical high/low temperature gradient at a wall with fixed temperature).
Does anyone know how to correctly calculate the temperature gradient for the whole internal Field?
Regards
Philipp
Philipp Dietrich is offline   Reply With Quote
creating an internal field? maybee OpenFOAM Programming & Development 2 February 4, 2021 18:15
calculate temperature gradient from temperature field xiyuqiu Main CFD Forum 14 July 30, 2012 15:38
how to perform temperature gradient on a particle (Thermophoretic Force) wwt650420 FLUENT 3 March 23, 2011 03:10
problem with temperature field in modeling evaporation with fluent MOhaj FLUENT 0 April 25, 2010 00:54
Temperature gradient Jaho CFX 2 March 12, 2009 20:36
