sampledSurface: size mismatch issue
Old   June 16, 2014, 06:28
Default sampledSurface: size mismatch issue
YS
Ya_Squall2010 is on a distinguished road
Hi everyone,
The sampledSurface "size mismatch" problem has been bothering me for quite a while. Basically what I am trying to do is to get a sampled normal velocity field on a sampling surface defined by a STL file using the sampledTriSurfaceMesh class. The code is something like following. And from time to time I get error message: "size mismatch: field XXX != surface XXX", which is really annoying. Can anyone give a hint how to solve this issue. Thanks a lot in advance!
const sampledTriSurfaceMesh& pln = velTriSurf_[planeI];
label nFaces = pln.faces().size();
reduce(nFaces, sumOp<label>());
if (nFaces)
interpolationCellPoint<vector> UInterp(U);
scalarField UInterpPl(pln.project(pln.interpolate(UInterp)));
SubList<face> plnFaces(pln.faces(), pln.faces().size());
primitivePatch primitivePtch(plnFaces, pln.points());
primitivePatchInterpolation primPatchInterp(primitivePtch);
scalarField UInterpPlFaces(primPatchInterp.pointToFaceInterpol ate(UInterpPl));
massFlow = pln.integrate(UInterpPlFaces);
Ya_Squall2010 is offline   Reply With Quote
Old   June 17, 2014, 01:58
YS
the "interpolate" switch must be set to "false" to dismiss this annoying error. This way the sampling will be based on the surface triangle centers. Otherwise, it will be performed based on the surface points. By setting "interpolate" to "true", you have high chance to be hit by the "size mismatch" error. And there's no way to perform the "project" operation where a fieldSizeCheck will be performed. Can anyone explain why the sampledSurface has been designed this way? Thanks a lot!
catalogue size problem steven CFX 4 May 30, 2012 08:23
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
Guides for calculation of mesh size for combustion Luk CFX 4 March 17, 2008 03:34
Gambit Size functions issue jon FLUENT 1 December 13, 2006 11:39
