Overwrite subdictionary using a string at runtime
Old   June 7, 2014, 07:05
Default Overwrite subdictionary using a string at runtime
Robert Sawko
AlmostSurelyRob will become famous soon enough
I am looking for a way to insert a string into a subdictionary during runtime. This is not an elegant solution and it's part of a workaround to OpenFOAM 2.2.x port of Mesquite. I am discussing the reasons for this workaround with the creator of the port over here:
https://github.com/smenon/dynamicTopoFvMesh/issues/4
I would like to place patch information into a subdictionary. The main problem is that the patches are not an IO object and they are read from dynamicMeshDict. For separate reasons I would like to keep it like this for now. I will describe the situation in steps:
Info << fvpDict << endl;
results in
    GEOM
        type sixDoFRigidBodyDisplacement;
        centreOfMass    ( 0.5 0.83 0 );
        momentOfInertia ( 1 1 0.01 );
        mass       0.01;
        rhoName     rhoInf;
        rhoInf          1000;
        report          on;
        accelerationRelaxation 0.5;
        value           uniform ( 0 0 0 );
being printed in the log file. Now I update the patch field by
pField().updateCoeffs();
Info << pField() << endl;
pField is an autoPtr so I need (). This recalculates 6DoF so the print out says:
rhoName         rhoInf;
rhoInf          1000;
g               (0 0 0);
centreOfMass    (0.5 0.83 0);
orientation     (1 0 0 0 1 0 0 0 1);
velocity        (-0.0008491605002 -2.316277561e-20 -1.253434956e-22);
acceleration    (-16.98321 -4.632555122e-16 -2.506869911e-18);
angularMomentum (7.472962772e-24 -6.482573965e-25 -7.048032152e-06);
torque          (1.494592554e-19 -1.296514793e-20 -0.140960643);
initialCentreOfMass (0.5 0.83 0);
initialOrientation (1 0 0 0 1 0 0 0 1);
momentOfInertia (1 1 0.01);
mass            0.01;
report          on;
initialPoints   nonuniform List<vector>
168
(0 -0.9499999881 0.02828427125)
(0 -0.9499999881 -0.02828427125)
(-0.03436942399 -0.9363066554 -0.02828427125)
(-0.03436942399 -0.9363066554 0.02828427125)
(0.03436942026 -0.9363066554 0.02828427125)
(0.03436942026 -0.9363066554 -0.02828427125)
(0 0.9499999881 0.02828427125)
(-0.03436942399 0.9363066554 0.02828427125)
(-0.03436942399 0.9363066554 -0.02828427125)
(0 0.9499999881 -0.02828427125)
(0.03436942026 0.9363066554 -0.02828427125)
(0.03436942026 0.9363066554 0.02828427125)
(-0.05000000075 0.8550000191 0.02828427125)
(-0.05000000075 0.8550000191 -0.02828427125)
(-0.05000000075 0.8999999762 -0.02828427125)
(-0.05000000075 0.8999999762 0.02828427125)
(0.05000000075 0.8550000191 0.02828427125)
(0.05000000075 0.8999999762 0.02828427125)
(0.05000000075 0.8999999762 -0.02828427125)
(0.05000000075 0.8550000191 -0.02828427125)
(0.05000000075 -0.8550000191 0.02828427125)
(0.05000000075 -0.8550000191 -0.02828427125)
(0.05000000075 -0.8999999762 -0.02828427125)
(0.05000000075 -0.8999999762 0.02828427125)
(-0.05000000075 -0.8550000191 0.02828427125)
(-0.05000000075 -0.8999999762 0.02828427125)
(-0.05000000075 -0.8999999762 -0.02828427125)
(-0.05000000075 -0.8550000191 -0.02828427125)
(0.05000000075 -0.2849999964 0.02828427125)
(0.05000000075 -0.2849999964 -0.02828427125)
(0.05000000075 -0.3324999809 -0.02828427125)
(0.05000000075 -0.3324999809 0.02828427125)
(0.05000000075 -0.237499997 0.02828427125)
(0.05000000075 -0.237499997 -0.02828427125)
(-0.05000000075 -0.8075000048 -0.02828427125)
(-0.05000000075 -0.8075000048 0.02828427125)
(-0.05000000075 -0.7599999905 0.02828427125)
(-0.05000000075 -0.7599999905 -0.02828427125)
(0.05000000075 -0.5699999928 0.02828427125)
(0.05000000075 -0.5699999928 -0.02828427125)
(0.05000000075 -0.6174999475 -0.02828427125)
(0.05000000075 -0.6174999475 0.02828427125)
(0.05000000075 -0.6649999619 0.02828427125)
(0.05000000075 -0.6649999619 -0.02828427125)
(0.05000000075 -0.5224999785 0.02828427125)
(0.05000000075 -0.5224999785 -0.02828427125)
(0.05000000075 -0.474999994 0.02828427125)
(0.05000000075 -0.474999994 -0.02828427125)
(0.05000000075 -0.4275000095 0.02828427125)
(0.05000000075 -0.4275000095 -0.02828427125)
(0.05000000075 -0.7124999762 -0.02828427125)
(0.05000000075 -0.7124999762 0.02828427125)
(0.05000000075 -0.7599999905 0.02828427125)
(0.05000000075 -0.7599999905 -0.02828427125)
(0.05000000075 -0.8075000048 0.02828427125)
(0.05000000075 -0.8075000048 -0.02828427125)
(-0.05000000075 -0.5699999928 0.02828427125)
(-0.05000000075 -0.5699999928 -0.02828427125)
(-0.05000000075 -0.5224999785 -0.02828427125)
(-0.05000000075 -0.5224999785 0.02828427125)
(-0.05000000075 -0.474999994 0.02828427125)
(-0.05000000075 -0.474999994 -0.02828427125)
(-0.05000000075 -0.4275000095 -0.02828427125)
(-0.05000000075 -0.4275000095 0.02828427125)
(-0.05000000075 -0.6649999619 0.02828427125)
(-0.05000000075 -0.7124999762 0.02828427125)
(-0.05000000075 -0.7124999762 -0.02828427125)
(-0.05000000075 -0.6649999619 -0.02828427125)
(-0.05000000075 -0.6174999475 0.02828427125)
(-0.05000000075 -0.6174999475 -0.02828427125)
(0.05000000075 0.3799999952 0.02828427125)
(0.05000000075 0.3799999952 -0.02828427125)
(0.05000000075 0.3324999809 -0.02828427125)
(0.05000000075 0.3324999809 0.02828427125)
(0.05000000075 0.4275000095 0.02828427125)
(0.05000000075 0.4275000095 -0.02828427125)
(0.05000000075 0.474999994 0.02828427125)
(0.05000000075 0.474999994 -0.02828427125)
(-0.05000000075 0.474999994 0.02828427125)
(-0.05000000075 0.4275000095 0.02828427125)
(-0.05000000075 0.4275000095 -0.02828427125)
(-0.05000000075 0.474999994 -0.02828427125)
(-0.05000000075 0.5224999785 -0.02828427125)
(-0.05000000075 0.5224999785 0.02828427125)
(0.05000000075 0.6649999619 0.02828427125)
(0.05000000075 0.7124999762 0.02828427125)
(0.05000000075 0.7124999762 -0.02828427125)
(0.05000000075 0.6649999619 -0.02828427125)
(0.05000000075 0.8075000048 -0.02828427125)
(0.05000000075 0.8075000048 0.02828427125)
(0.05000000075 0.5224999785 0.02828427125)
(0.05000000075 0.5224999785 -0.02828427125)
(0.05000000075 0.6174999475 -0.02828427125)
(0.05000000075 0.6174999475 0.02828427125)
(0.05000000075 0.5699999928 0.02828427125)
(0.05000000075 0.5699999928 -0.02828427125)
(-0.05000000075 0.6649999619 0.02828427125)
(-0.05000000075 0.6174999475 0.02828427125)
(-0.05000000075 0.6174999475 -0.02828427125)
(-0.05000000075 0.6649999619 -0.02828427125)
(-0.05000000075 0.7124999762 -0.02828427125)
(-0.05000000075 0.7124999762 0.02828427125)
(-0.05000000075 0.8075000048 0.02828427125)
(-0.05000000075 0.8075000048 -0.02828427125)
(0.05000000075 0.2849999964 0.02828427125)
(0.05000000075 0.2849999964 -0.02828427125)
(-0.05000000075 0.2849999964 0.02828427125)
(-0.05000000075 0.237499997 0.02828427125)
(-0.05000000075 0.237499997 -0.02828427125)
(-0.05000000075 0.2849999964 -0.02828427125)
(-0.05000000075 0.3324999809 -0.02828427125)
(-0.05000000075 0.3324999809 0.02828427125)
(0.05000000075 0.09499999881 0.02828427125)
(0.05000000075 0.09499999881 -0.02828427125)
(0.05000000075 0.0474999994 -0.02828427125)
(0.05000000075 0.0474999994 0.02828427125)
(-0.05000000075 0.09499999881 0.02828427125)
(-0.05000000075 0.0474999994 0.02828427125)
(-0.05000000075 0.0474999994 -0.02828427125)
(-0.05000000075 0.09499999881 -0.02828427125)
(-0.05000000075 0.1424999982 -0.02828427125)
(-0.05000000075 0.1424999982 0.02828427125)
(0.05000000075 0.1424999982 0.02828427125)
(0.05000000075 0.1424999982 -0.02828427125)
(0.05000000075 0.1899999976 0.02828427125)
(0.05000000075 0.1899999976 -0.02828427125)
(0.05000000075 0.237499997 -0.02828427125)
(0.05000000075 0.237499997 0.02828427125)
(-0.05000000075 -0.2849999964 0.02828427125)
(-0.05000000075 -0.2849999964 -0.02828427125)
(-0.05000000075 -0.237499997 -0.02828427125)
(-0.05000000075 -0.237499997 0.02828427125)
(-0.05000000075 -0.3324999809 0.02828427125)
(-0.05000000075 -0.3324999809 -0.02828427125)
(0.05000000075 -0.09499999881 0.02828427125)
(0.05000000075 -0.09499999881 -0.02828427125)
(0.05000000075 -0.1424999982 -0.02828427125)
(0.05000000075 -0.1424999982 0.02828427125)
(-0.05000000075 -0.09499999881 0.02828427125)
(-0.05000000075 -0.1424999982 0.02828427125)
(-0.05000000075 -0.1424999982 -0.02828427125)
(-0.05000000075 -0.09499999881 -0.02828427125)
(-0.05000000075 -0.0474999994 -0.02828427125)
(-0.05000000075 -0.0474999994 0.02828427125)
(0.05000000075 -0.0474999994 0.02828427125)
(0.05000000075 -0.0474999994 -0.02828427125)
(0.05000000075 -0.1899999976 0.02828427125)
(0.05000000075 -0.1899999976 -0.02828427125)
(-0.05000000075 -0.1899999976 0.02828427125)
(-0.05000000075 -0.1899999976 -0.02828427125)
(-0.05000000075 0.1899999976 0.02828427125)
(-0.05000000075 0.1899999976 -0.02828427125)
(-0.05000000075 0.5699999928 0.02828427125)
(-0.05000000075 0.5699999928 -0.02828427125)
(0.05000000075 -0.3799999952 0.02828427125)
(0.05000000075 -0.3799999952 -0.02828427125)
(-0.05000000075 -0.3799999952 0.02828427125)
(-0.05000000075 -0.3799999952 -0.02828427125)
(-0.05000000075 0.3799999952 0.02828427125)
(-0.05000000075 0.3799999952 -0.02828427125)
(0.05000000075 0.7599999905 0.02828427125)
(0.05000000075 0.7599999905 -0.02828427125)
(-0.05000000075 0.7599999905 0.02828427125)
(-0.05000000075 0.7599999905 -0.02828427125)
(-0.05000000075 0 0.02828427125)
(-0.05000000075 0 -0.02828427125)
(0.05000000075 0 0.02828427125)
(0.05000000075 0 -0.02828427125)
value           nonuniform List<vector>
168
(0 0 0)
(0 0 0)
(2.081668171e-17 0 0)
(6.938893904e-18 0 0)
(0 0 0)
(0 0 0)
(-6.938893904e-18 0 0)
(-6.938893904e-18 1.110223025e-16 0)
(6.938893904e-18 1.110223025e-16 0)
(-6.938893904e-18 5.551115123e-17 0)
(-6.938893904e-18 8.326672685e-17 0)
(-6.938893904e-18 -1.110223025e-16 0)
(6.938893904e-18 -1.110223025e-16 0)
(6.938893904e-18 5.551115123e-17 0)
(-6.938893904e-18 -5.551115123e-17 0)
(6.938893904e-18 -5.551115123e-17 0)
(6.938893904e-18 2.775557562e-17 0)
(-6.938893904e-18 -1.387778781e-17 0)
(-6.938893904e-18 4.857225733e-17 0)
(6.938893904e-18 -1.387778781e-17 0)
(6.938893904e-18 4.857225733e-17 0)
(-6.938893904e-18 2.775557562e-17 0)
(-6.938893904e-18 -2.775557562e-17 0)
(6.938893904e-18 8.326672685e-17 0)
(-6.938893904e-18 1.387778781e-17 0)
(6.938893904e-18 1.387778781e-17 0)
(6.938893904e-18 -2.775557562e-17 0)
(6.938893904e-18 -4.857225733e-17 0)
(-6.938893904e-18 -4.857225733e-17 0)
(-6.938893904e-18 -8.326672685e-17 0)
(6.938893904e-18 -8.326672685e-17 0)
Is there any way to substitute the former with the latter in fvpDict? I've tried a number of things involving set, add and clear and only clear worked for me. Basically I would like to clear GEOM entry during runtime and put a new one which corresponds to updated pField.
Please let me know if that's possible with current implementation of dictionary object.
AlmostSurelyRob is offline   Reply With Quote
runTime deji OpenFOAM 2 January 17, 2019 10:14
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 05:40
Creating a new field from terms of the turbulence model HaZe OpenFOAM Programming & Development 15 November 24, 2014 14:51
runTime out of scope in functionObject Sune OpenFOAM Programming & Development 2 September 26, 2012 03:11
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
