how to define a vector5(5 primitive variables) in Block matrix?
Old   June 2, 2014, 23:15
Default how to define a vector5(5 primitive variables) in Block matrix?
hua1015's Avatar
Hua
hua1015 is on a distinguished road
Dear Foamers,
Recently, I want to define a vector5(5 primitive variables,u,v,w,p,T) in block matrix. vector2,3,4,6,8 have been defined in OpenFOAM. So I added some codes to define vector5.
follow is my codes
//vector5 and some relative variables***************************************** ******************************** //
#include "ExpandTensorN.H"
#define nGroups 5
typedef Foam::VectorN<scalar, nGroups> vector5;
typedef Foam::TensorN<scalar, nGroups> tensor5;
typedef Foam:iagTensorN<scalar, nGroups> diagTensor5;
typedef Foam::SphericalTensorN<scalar, nGroups> sphericalTensor5;
typedef dimensioned<vector5> dimensionedVector5;
typedef dimensioned<tensor5> dimensionedTensor5;
typedef dimensioned<diagTensor5> dimensionedDiagTensor5;
typedef dimensioned<sphericalTensor5> dimensionedSphericalTensor5;
typedef GeometricField<vector5, fvPatchField, volMesh> volVector5Field;
typedef GeometricField<tensor5, fvPatchField, volMesh> volTensor5Field;
typedef GeometricField<diagTensor5, fvPatchField, volMesh> voldiagTensor5Field;
typedef GeometricField<sphericalTensor5, fvPatchField, volMesh> volsphericalTensor5Field;
Unlucky, compilation is error.
Could anyone can help me?
hua1015 is offline   Reply With Quote
Old   June 3, 2014, 04:13
hua1015's Avatar
Hua
My openFoam is openfoam-extend-3.0.
Old   June 4, 2014, 01:18
hua1015's Avatar
Hua
I had solved this problem.Thanks
Old   May 14, 2015, 13:58
Anant Grewal
agrewal is on a distinguished road
Could you please post how you did this? I have the same requirement for a vector of 5 scalars.
Thanks
Anant
agrewal is offline   Reply With Quote
Old   May 15, 2015, 11:46
hua1015's Avatar
Hua
Hi,Anant,
I remembered there some change should be done in source codes in OF-ext3,0.
Since vector2,3,4,6,8 have been defined in OpenFOAM. So I added some codes to define vector5 just like vector2,3,4,6,8 in source codes.
follow is my codes
#define nGroups 5
Good luck.
There some more change may be needed. Try it and follow the error to find something needed.
Force can not converge colopolo CFX 13 October 4, 2011 23:03
UDF to define variables orlik FLUENT 0 March 11, 2010 12:15
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
writing a 3d NS solver in the primitive variables! lostsoul Main CFD Forum 4 October 20, 2000 03:52
