tailor made class, wmake libso successfully, but run failed.
Old   June 2, 2014, 22:55
Default tailor made class, wmake libso successfully, but run failed.
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
This is my class:
class definition:
namespace Foam
			  Class gaussianDistribution Declaration
class gaussianDistribution
private:
    // Private data
        //- Parameter sigma
        double sigma_;
	//- Moments from previous value
	const scalarDiagonalMatrix moments_;
	//- Quadrature weights
	scalarDiagonalMatrix weights_;
	//- Quadrature abscissas
	scalarDiagonalMatrix abscissas_;
	//- Number of weights and abscissas
	const label nWeights_;
	//- Number of moments
	const label nMoments_;
    //- Private member functions
	//- Disallow default bitwise copy construct
	gaussianDistribution(const gaussianDistribution&);
	//- Disallow default bitwise assignment
	void operator=(const gaussianDistribution&);
public:
    // Constructors
	//- Construct from a scalarSquareMatrix
	    const double& sigma,
	    const scalarDiagonalMatrix& moments,
Foam::gaussianDistribution::gaussianDistribution
    sigma_(sigma),
    moments_(moments),
    weights_(nWeights),
    abscissas_(nWeights),
    nWeights_(nWeights),
    nMoments_(nWeights*2)
    scalarDiagonalMatrix we(nWeights_, scalar(0));
    scalarDiagonalMatrix abs(nWeights_, scalar(0));
    scalarSquareMatrix A(nMoments_, nMoments_, scalar(0));
    // Construct A matrix
    A[2][0] = Foam::pow(sigma_,2);
    A[3][1] = Foam::pow(sigma_,2);
    Info << A <<endl;
This is my main function:
int main(int argc, char *argv[])
	scalarDiagonalMatrix m(4, scalar(1));
	Info << m << endl;
	gaussianDistribution(4.0, m, 1);
	return 0;
You can see that I just wanna see if this class works. But it said:
a@a:~/OpenFOAM/myCase/momentsinversion$ C
4{1}
Segmentation fault (core dumped)
Any ideas? Thanks
Solved..gaussianDistribution(4.0, m, 4) works.
sharonyue is offline   Reply With Quote
Old   November 20, 2014, 22:49
Huang Xianbei
huangxianbei is on a distinguished road
Hi:
Could you please explain a little bit about how to use the new namespace when it's compiled with wmake libso?
Xianbei
huangxianbei is offline   Reply With Quote
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 07:21
[solidMechanics] Building solidMechanics in OpenFOAM 1.6-ext on Mac OS X codder OpenFOAM CC Toolkits for Fluid-Structure Interaction 4 January 11, 2014 18:34
compiling firefoam Farshad_Noravesh OpenFOAM 27 December 24, 2012 05:21
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
how to run successfully? blue moon Phoenics 5 May 22, 2001 10:00
