May 29, 2014, 06:46 |
Right way to compute boundary diffusion term
bou
Rep Power: 12 |
Dear,
I am looking for a way to compute diffusion term (see Jasak PHD, 3.59 section 3.3.3.1) through a boundary. I have read in other posts that I should use snGrad(T) method instead of simple grad(T) method at the boundary. Indeed, I only managed to use grad(T) and the results seem not to be good. The problem is that snGrad method cannot be applied to a patchField that results from the method boundaryField()[patchID]... Actually I am not sure to understand the type of object returned by snGrad method, it seems not to be a vectorField and this is what I would need to compute the diffusion term through the boundary. I found this that could be related to my problem but I did not manage to make it work: http://www.cfd-online.com/Forums/ope...tions-how.html. Can you please help me with this? Best regards, Bou |
May 29, 2014, 09:48 |
Thamali
Rep Power: 13 |
refer following presentation.think it might help you.
http://powerlab.fsb.hr/ped/kturbo/Op...niteVolume.pdf |
May 29, 2014, 12:21 |
bou
Rep Power: 12 |
Thank you for your reply and the provided presentation.
Unfortunately, it seems there is not so much practical details about the way to proceed using the C++ code. I think that trying to reconstruct the gradient value from fundamental notions is not a good idea. It must exist a way to that using predefined methods. Thank you anyway, Bou |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
outflow boundary in a steady state 1D convection diffusion eq. | hans-186 | Main CFD Forum | 2 | October 14, 2012 18:39 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 20:23 |
