May 28, 2014, 10:31 |
Find intersection between surface and mesh
mike
Rep Power: 12 |
I'm trying to write a personal solver based on PISO. I have to generate a cylinder and then find the intersection between this cylinder and my mesh. The mesh is a cube with only cube element. I want to save this intersection point in an dynamicList and after in this point i want to setup the velocity vector. Can you help me? Thanks very much. |
intersection surface mesh |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
