problem with RBF in tho Foam 3.0 extend
Old   May 28, 2014, 09:51
Default problem with RBF in tho Foam 3.0 extend
Vaclav Ridky
Vesek is on a distinguished road
I have a problem with compiling solver for RBF. When you compile a report that I can not find functionObject.H. When he enters the path to the file directly and then again can not find another Header file from this file. I want to ask if anyone has the same problem. My idea if it can not be because I installed the foam as a binary package
When you start the tutorial follows this statement:
 Compiling RBFMotionFunction application
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file RBFMotionFunctionObject.C
could not open file functionObject.H for source file RBFMotionFunctionObject.C
could not open file dictionary.H for source file RBFMotionFunctionObject.C
could not open file pointField.H for source file RBFMotionFunctionObject.C
could not open file addToRunTimeSelectionTable.H for source file RBFMotionFunctionObject.C
could not open file objectRegistry.H for source file RBFMotionFunctionObject.C
could not open file Time.H for source file RBFMotionFunctionObject.C
could not open file RBFMotionSolver.H for source file RBFMotionFunctionObject.C
SOURCE=RBFMotionFunctionObject.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/opt/foam/foam-extend-3.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/opt/foam/foam-extend-3.0/src/dynamicMesh/meshMotion/RBFMotionSolver/lnInclude     -I/opt/foam/foam-extend-3.0/src/finiteVolume/lnInclude     -I/opt/foam/foam-extend-3.0/src/meshTools/lnInclude     -I/opt/foam/foam-extend-3.0/src/triSurface/lnInclude -IlnInclude -I. -I/opt/foam/foam-extend-3.0/src/foam/lnInclude -I/opt/foam/foam-extend-3.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/RBFMotionFunctionObject.o
In file included from RBFMotionFunctionObject.C:29:0:
RBFMotionFunctionObject.H:41:28: fatal error: functionObject.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/RBFMotionFunctionObject.o] Error 1
blockMesh already run on /home/vasek/foam/vasek-3.0/run/RBF: remove log file to run
icoDyMFoam already run on /home/vasek/foam/vasek-3.0/run/RBF: remove log file to run
It is a Foam extend 3.0 on Ubuntu 12.4
Vesek is offline   Reply With Quote
Old   June 1, 2014, 11:13
Retired Super Moderator
Bruno Santos
Greetings Vesek and welcome to the OpenFOAM forum!
I would like to try out this myself with an installation I have of foam-extend 3.0, built from source code. But I can't figure out which tutorial you're referring to and where you got it from.
Therefore, if you could provide a bit more information on how we can try and reproduce the same problem, i.e. where we can find the example case you're using, it'll be easier to diagnose the problem.
Best regards,
Bruno
Old   June 1, 2014, 17:38
Vaclav Ridky
Hello Bruno I used case in the tutorial for icoDyMFoam
/foam-extend-3.0/tutorials/incompressible/icoDyMFoam/movingBlockRBF
Here are also source code for RBF.
Best regards,
Vasek
Old   June 9, 2014, 08:33
Bruno Santos
I've finally managed to get to this thread.
Indeed the problem is in the Deb package for foam-extend 3.0 and was reported some time ago here: http://sourceforge.net/apps/mantisbt...iew.php?id=200
According to the bug report, the quick solution is to run:
sudo wmakeAllLnInclude $FOAM_SRC
Then you can try building the library once again!
Best regards,
Bruno
Old   June 16, 2014, 05:22
Vaclav Ridky
Bruno Thank you for your advice. Neither these solutions do not work, I finally had to compile Foam and everything has been running as it should.
Best regards,
Vasek
foam extend, rbf
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 08:58
problem in running FoamX in Open FOAM Gaurav Main CFD Forum 3 May 10, 2006 06:06
problem about installing FOAM linux freshman Main CFD Forum 6 November 4, 2004 11:59
