May 26, 2014, 15:02 |
how to install real gas extension?
Maciej
I ask you to help me to install real gas extension since it's overwhelming me. Here's an error which i got: In file included from IAPWSThermo/IAPWSThermo.H:191:0, from IAPWSThermo/IAPWSThermos.C:35: IAPWSThermo/IAPWSThermo.C: In member function ‘void Foam::IAPWSThermo::calculate()’: IAPWSThermo/IAPWSThermo.C:44:35: error: ‘class Foam::IAPWSThermo’ has no member named ‘psi_’ IAPWSThermo/IAPWSThermo.C:46:34: error: ‘class Foam::IAPWSThermo’ has no member named ‘mu_’ IAPWSThermo/IAPWSThermo.C:72:42: error: ‘class Foam::IAPWSThermo’ has no member named ‘psi_’ IAPWSThermo/IAPWSThermo.C:76:41: error: ‘class Foam::IAPWSThermo’ has no member named ‘mu_’ IAPWSThermo/IAPWSThermo.C: In constructor ‘Foam::IAPWSThermo::IAPWSThermo(const Foam::fvMesh&)’: IAPWSThermo/IAPWSThermo.C:140:15: error: ‘class Foam::IAPWSThermo’ has no member named ‘hBoundaryTypes’ IAPWSThermo/IAPWSThermo.C:199:27: error: ‘hBoundaryCorrection’ was not declared in this scope IAPWSThermo/IAPWSThermo.C:204:11: error: ‘class Foam::IAPWSThermo’ has no member named ‘psi_’ IAPWSThermo/IAPWSThermo.C: In member function ‘virtual void Foam::IAPWSThermo::correct()’: IAPWSThermo/IAPWSThermo.C:226:11: error: ‘class Foam::IAPWSThermo’ has no member named ‘psi_’ In file included from /opt/openfoam222/src/thermophysicalModels/basic/psiThermo/basicPsiThermo/makeBasicPsiThermo.H:35:0, from IAPWSThermo/IAPWSThermos.C:34: I'm looking forward your reply. |
May 31, 2014, 12:21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Maciej and welcome to the forum!
I can see that you're using OpenFOAM 2.2.2, from the output messages. But I have no idea as to which "real gas extension" you're referring to. Best regards, Bruno
June 4, 2014, 09:43 |
Maciej
Thank you that you reply on my post. I've tried to install real gas model which i found in : https://github.com/morgoth541/of_realFluid
June 6, 2014, 16:28 |
Bruno Santos
Rep Power: 128 |
Hi Maciej,
Well, I guess the first question is: what was the procedure you used for adapting the code from that repository to OpenFOAM 2.2.2? I ask this because that repository is a completely modified OpenFOAM 2.1.0, which means that upgrading customized code isn't straight forward, since there was a big jump in modifications between OpenFOAM 2.1.0 to 2.2.0. I don't have the time to look into this myself any time soon, so the best I can suggest is that you have a look into this repository of mine: https://github.com/wyldckat/OpenFOAM-combo/ - it provides an almost complete history of the evolution of the OpenFOAM source code, which should make it easier for you to study the changes that were made from OpenFOAM 2.1.0 to 2.2.0. This way it should be a bit easier to adapt the source code found on that repository you've indicated, to OpenFOAM 2.2.2. edit: Have a look into this thread, as it should give a few more hints: http://www.cfd-online.com/Forums/ope...perties-4.html Best regards, Bruno
openfoam, real gas |
UDF for variable temperature with time | CaglarCoskun | Fluent UDF and Scheme Programming | 8 | January 15, 2014 10:15 |
help me check udf | tranvantrung551987 | Fluent UDF and Scheme Programming | 0 | August 23, 2013 06:55 |
how to hook this udf | shanu | FLUENT | 1 | August 26, 2011 11:48 |
Real gas equation of state for gas mixture | ahourri | FLUENT | 0 | April 30, 2008 12:23 |
FLUENT received fatal signal (ACCESS_VIOLATION) | samy | FLUENT | 0 | November 10, 2007 14:09 |
