Development of partially premixed solver in OpenFoam
Old   May 21, 2014, 16:32
Default Development of partially premixed solver in OpenFoam
Harshad Lalit
harshad88 is on a distinguished road
Hello all,
I would like to develop a partially premixed solver in OpenFoam. The test case comprises of a premixed burner of methane+air with coflow of air from the sides. I know that Openfoam has lot many solvers for non-premixed combustion with the equation for mixture fraction implemented. I would like to add an equation for progress variable with the requisite combustion model to make it partially premixed.
Can anyone point me the right direction as to the steps how to implement this. Any help would be much appreciated.
Thanks
harshad88 is offline   Reply With Quote
Old   May 22, 2014, 10:46
Bobby
babakflame is on a distinguished road
Greetings Harshad
FSD combustion model available in openfoam is based on partially premixed theories.
Bobi
babakflame is offline   Reply With Quote
Old   May 23, 2014, 01:11
Harshad Lalit
Hi Bobi,
Thanks for your reply, this information really helps
I am very new to OpenFoam so would also like to ask that since I would have both the mixture fraction and the progress variable equation so solve for, I would need some kind of state relationships to get my mean scalars.
Is there any way of integrating OPPDIFF/PREMIX to OpenFoam or has work in this area been done before with OpenFoam?
Old   May 23, 2014, 01:35
Bobby
Greetings
PHP Code:
If you use FSD combustion model, you will have the mean scalars beforehand.
PHP Code:
My field of interest is not Premixed combustion. However, FSD combustion model available in Openfoam is roughly suitable, except that you can only use global chemistry with it. The most interesting point about this model is the way of implementing beta-pdf integration.
Another solver that supports detailed chemistry and is for premixed combustion is Xifoam.
By searching in Google you will find good tutorials for this solver.
Bobi
Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam jovani OpenFOAM Running, Solving & CFD 475 January 13, 2023 09:21
Can't get data from OpenFoam to external solver using externalCoupled perry OpenFOAM Running, Solving & CFD 4 May 26, 2014 09:09
FSI solver for openFoam 1.6 ext Whyman OpenFOAM 4 October 26, 2013 07:11
Building a custom solver on OpenFOAM 2.0 wschosta OpenFOAM Programming & Development 1 July 8, 2011 16:07
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
