Programming phase dependant velocity boundary condition |
May 21, 2014, 09:10 |
Peter
Rep Power: 12 |
Hi foamers,
I am running a filling simulation of a porous medium using the porousInterFoam solver. My 2D-rectangular computational domain is filled initially with air. Starting from an inlet, it is filled up with a liquid. I like to have a routine that switches the U boundary condition of one of the walls from "fixed value = 0" to "zeroGradient", depending on the phase that it is in contact with. I want to simulate a special kind of infusion of resin into fibres. The special thing is that one side of the mould is covered with a membrane, which is so densely woven that air can pass though but not the resin. I think I can model this behavior by switch the velocity BC from impermeable wall (fixed value =0) to outlet (zeroGradient) while the vacuum pressure which drives the flow stays constant for both conditions. So far I tried a codedFixedValue boundary condition. (Accidentally I did it in the p_rgh file, but it sould be similar in the U file) The problem is that I wasn't able to implement a zeroGradient BC this way. Now, I'm implementing a #codeStream in the U file. I want it to access the alpha values on the boundary and do an if look for every cell. If alpha is > 0.5, it sould see the cell as filled and define the BC as fixedValue=0. But I'm not even able to access the alpha data, not to mention taking influence on the actual boundaries. Please find attached a sketch of the problem and my input files containing my poor programming essays in the U and p_rgh files. Thank you very much for your time and effort. Kind regards, Peter My U file: Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { leftWall { type fixedValue; value uniform (0 0 0); } rightWall { type fixedValue; value uniform (0 0 0); } lowerWall { type fixedValue; value uniform (0 0 0); } upperWall // the following code is derived from the one in the p_rgh file. There it is a codedFixedValue BD, rather than a #codeStream #codeStream { code #{ // save values of alpha.matrix to scalar field alpha1 // gives error: ‘volScalarField’ was not declared in this scope volScalarField& alpha1 = const_cast<volScalarField&>(db().lookupObject<volScalarField>("alpha.matrix")); // check: prints alphas for Cells specified by the number in [] Info << "alpha1: " << alpha1[300] << endl; // what's written in the input file for alpha? gives: type zeroGradient fvPatchField& alphasOnBoundary = const_cast<fvPatchField&>(alpha1.boundaryField()[IDupperWall]); Info << "alphasOnBoundary: " << alphasOnBoundary << endl; forAll(patch(), facei) // facei: cell faces { label celli = patch().faceCells()[facei]; // get global cell indices for cells adjacent to patch if (alpha1[celli] < 0.5) // if cell is "not" filled with resin { // I want U to be zeroGradient Info << "alpha 1 is LOWER than 0.5" << endl; } else // if cell is filled with resin { // I want U to be fixedValue; uniform (0 0 0) Info << "alpha 1 is HIGHER than 0.5" << endl; } } #}; codeInclude // try to make volScalarField available. New Error: problem while reading string "#include "volFields.H" ... #{ #include "volFields.H" }#; codeOptions // try to make volScalarField available. Same error as with codeInclude #{ -I$(LIB_SRC)/finiteVolume/lnInclude }# }; /* upperWall // default values { ..." #{ #include "volFields.H" }# }; /* upperWall // default values { type fixedValue; value uniform (0 0 0); } */ inlet { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet { type zeroGradient; } defaultFaces { type empty; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { Porosity { type fixedFluxPressure; value uniform 0; } lowerWall { type fixedFluxPressure; value uniform 0; } /* upperWall { type fixedFluxPressure; value uniform 0; } */ upperWall { type codedFixedValue; value uniform 0; redirectType ramp; code // this is only a test on how to access data (alpha.matrix). My aim is to get the code in the U file running and use the same p_rgh BC for upperWall as for outlet #{ // save values of alpha.matrix to scalar field alpha1, that works volScalarField& alpha1 = const_cast<volScalarField&>(db().lookupObject<volScalarField>("alpha.matrix")); // works // to check: print alpha value for Cells specified by the number in [] Info << "alpha1: " << alpha1[300] << endl; // find the patch ID of the BC patch upperWall const int IDupperWall = patch().boundaryMesh().findPatchID("upperWall"); // print the patch ID of the boundary patch upperWall Info << "IDupperWall: " << IDupperWall << endl; /* // see what's written in the initial file output: type zeroGrandient; fvPatchField& inputAlpha = alpha1.boundaryField()[IDupperWall]; // print type zeroGrandient; what's written in the initial file Info << "inputAlpha: " << inputAlpha << endl; // see what's written in the initial file output: type zeroGrandient; fvPatchField& alphasOnBoundary = const_cast<fvPatchField&>(alpha1.boundaryField()[IDupperWall]); // print type zeroGrandient; what's written in the initial file Info << "alphasOnBoundary: " << alphasOnBoundary << endl; */ forAll(patch(), facei) // facei: cell faces { // get global cell indices for cells adjacent to patch label celli = patch().faceCells()[facei]; // Info << "cell labels: " << celli << endl; // Info << "facei: " << facei << endl; Info << "alpha values on upperWall: " << alpha1[celli] << endl; if (alpha1[celli] < 0.5) // if cell is "not" filled { Info << "alpha in cell IS 0 " << endl; // I want U to be zeroGradient } else { Info << "alpha in cell is NOT 0 " << endl; // I want U to be fixedValue; uniform (0 0 0) } } #}; }; inlet { type fixedValue; // from Hanniel value uniform 3.5e4; } outlet { type fixedValue; // from Hanniel value uniform 0; // from Hanniel } defaultFaces { type empty; } } |
May 22, 2014, 09:14 |
Suggestion from a newbie
bou
Rep Power: 12 |
I am a newbie but in case this can help you... I am using groovyBc for time/field/space dependent Bc and it works fine. Is groovyBc not applicable for your case? (http://openfoamwiki.net/index.php/Contrib/swak4Foam) Regards, Bou |
May 22, 2014, 09:46 |
Peter
Rep Power: 12 |
Hi Bou,
thank you for your reply. I don't know about the capabilities of groovyBCs. Is it capable to switch from one type of BC to another? Or is it just able to adapt the values of one type, like for example fixedValue? However, they way I tried it is probably completely wrong. At the moment I’m trying to create a user defined boundary. Kind Regards, Peter |
May 22, 2014, 11:18 |
groovyBc
bou
Rep Power: 12 |
Absolutly,
Check this link (note groovyBc is a part of swak4foam); http://openfoamwiki.net/index.php/Contrib_groovyBC You have a lot of examples. As you can see you can switch between valueExpression and gradientExpression using fractionExpression. Bou |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Boundary condition programming | Andrea_Fen | STAR-CCM+ | 1 | July 9, 2013 08:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
Boundary condition for each phase | dungsidietquy | FLUENT | 0 | November 5, 2009 08:44 |
