Solver for superfluid helium based on Laplacian Foam
Old   May 19, 2014, 13:10
Default Solver for superfluid helium based on Laplacian Foam
Gennaro
Gennaro is on a distinguished road
Hi all,
I'm working on a superFluid helium solver based on Laplacian Foam.
The difference between LaplacianFoam and my solver is that the thermal conductivity k is replaced with keff which is a function of the gradient of the temperature.
This model was developed a few years ago and it is used in the cryogenic industry, but no one implemented it on OpenFOAM yet. I'm trying to do it although I'm relatively new to OpenFOAM programming and C++ programming.
So I created the solver, which compiles but crashes returning the following error:
Create time
Create mesh for time = 0
Reading field T
Reading thermophysicalProperties
Selecting thermodynamics package
type heSolidThermo;
mixture pureMixture;
transport polynomial;
thermo hPolynomial;
equationOfState rhoConst;
specie specie;
energy sensibleEnthalpy;
Reading Alambda
Reading Slambda
Reading Tlambda
No finite volume options present
Radiation model not active: radiationProperties not found
Selecting radiationModel none
Calculating temperature distribution
SIMPLE: no convergence criteria found. Calculations will run for 0.01 steps.
Time = 1e-06
#0 Foam::error:rintStack(Foam::Ostream&) in "/afs/cern.ch/project/cfd/OpenFOAM/SLC6/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/afs/cern.ch/project/cfd/OpenFOAM/SLC6/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
at sigaction.c:0
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/afs/cern.ch/project/cfd/OpenFOAM/SLC6/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/afs/cern.ch/user/g/gbozza/OpenFOAM/gbozza-2.3.x/platforms/linux64Gcc46DPOpt/bin/laplacianFoamCustom"
at laplacianFoamCustom.C:0
#7 __libc_start_main in "/lib64/libc.so.6"
Floating exception (core dumped)
I don't understand what SIMPLE: no convergence criteria found means.
Please find in attachment the solver and a case.
Can you please help?
Thanks
Best regards
Gennaro is offline   Reply With Quote
Old   October 3, 2017, 04:56
Libor Macek
libi.macek is on a distinguished road
Hello Gennaro,
Did you make any progressi in this problem?
I am interested in computation with superfluid.
Best regards. Libor
libi.macek is offline   Reply With Quote
Old   October 5, 2017, 09:01
Cyp
Cyprien
Cyp is on a distinguished road
Dear Libor,
please have a look at some papers we published with HellFOAM our superfluid helium simulator with OpenFOAM:
http://www.sciencedirect.com/science...10465514003415
https://journals.aps.org/prl/abstrac...ett.118.074506
http://oatao.univ-toulouse.fr/11935/...aine_11935.pdf
The first one described the algorithm we developed in OpenFOAM and some validation test cases. We uploaded the source code and you can download it here https://github.com/csoulain/HellFOAM
I haven't upgrade the code with the new OpenFOAM release, but I am sure you can do it easily.
Cheers,
Cyprien
Cyp is offline   Reply With Quote
Old   October 26, 2017, 04:18
Libor Macek
Thank you for advice
laplacianfoam, simple algorithm
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Pressure based and Density based Solver Xobile Main CFD Forum 39 August 19, 2020 07:04
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 07:44
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 30, 2015 00:42
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
