Modifying OF library
Old   May 15, 2014, 11:22
Default Modifying OF library
GPL65 is on a distinguished road
I'm a new forum user and I hello everyone, sorry for my english.
I'm trying to modify a OF library (KinematicCloud.H) but I don't want overwrite the program files.
Is it possible to put the user file in another location and link to it?
GPL65 is offline   Reply With Quote
Old   May 16, 2014, 08:00
dkxls's Avatar
Armin
dkxls will become famous soon enough
KinematicCloud.H is part of a templated library. It's not straight forward to make changes to KinematicCloud.H without recompiling the whole shebang, i.e. liblagrangianIntermediate.
What are you trying to do?
dkxls is offline   Reply With Quote
Old   May 16, 2014, 10:16
I have written a modify to this template class (I have added a function to this class), to do not overwrite the existing library I have copied it to my user source dir and I have compiled to my user lib dir, then I link solver to it (w/ Make/options files).
Is it a good job?
Thank you for patience.
Old   May 16, 2014, 10:25
dkxls's Avatar
Armin
I doubt that this will work just like that. Though I'm not quite sure.
So you are just interested in a KinematicCloud? No thermodynamics, collisions, ...
Old   May 16, 2014, 10:42
It seems to work, I wrote a function that calculate the penetration of a scalarField along injector direction, because I will use this function more and more I have inserted in this class (in analogy with liquid penetration)
My doubt is on the "orthodoxy" of this method, there is a smarter solution?
// Example of Make/options
EXE_INC = \
-I../include \
-I$(FOAM_SOLVERS)/lagrangian/reactingParcelFoam \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I${LIB_SRC}/meshTools/lnInclude \
-I${LIB_SRC}/sampling/lnInclude \
-I$(LIB_SRC)/turbulenceModels/compressible/turbulenceModel \
-I$(LIB_SRC)/lagrangian/basic/lnInclude \
-I$(FOAM_USER_SRC)/lagrangian/intermediate/lnInclude \
-I$(LIB_SRC)/lagrangian/spray/lnInclude \
-I$(LIB_SRC)/lagrangian/distributionModels/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/liquidProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/liquidMixtureProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/solidProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/properties/solidMixtureProperties/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/thermophysicalFunctions/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/SLGThermo/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/radiationModels/lnInclude \
-I$(LIB_SRC)/ODE/lnInclude \
-I$(LIB_SRC)/regionModels/regionModel/lnInclude \
-I$(LIB_SRC)/regionModels/surfaceFilmModels/lnInclude \
-I$(LIB_SRC)/fvOptions/lnInclude \
-I$(LIB_SRC)/combustionModels/lnInclude
EXE_LIBS = \
-L$(FOAM_USER_LIBBIN) \
-lfiniteVolume \
-lmeshTools \
-lsampling \
-lcompressibleTurbulenceModel \
-lcompressibleRASModels \
-lcompressibleLESModels \
-llagrangian \
-llagrangianTurbulence \
-llagrangianSpray \
-llagrangianIntermediate \
-lspecie \
-lfluidThermophysicalModels \
-lliquidProperties \
-lliquidMixtureProperties \
-lsolidProperties \
-lsolidMixtureProperties \
-lthermophysicalFunctions \
-lreactionThermophysicalModels \
-lSLGThermo \
-lchemistryModel \
-lradiationModels \
-lODE \
-lregionModels \
-lsurfaceFilmModels \
-lfvOptions \
-lcombustionModels
[Other] Multi species mass transport library [update] novyno OpenFOAM Community Contributions 111 November 10, 2021 00:37
ERROR: unable to find library HJH CFX 6 February 26, 2019 07:52
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 08:24
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 08:17
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
