wmake - options for parallel code using omp.h
Old   May 15, 2014, 09:30
Default wmake - options for parallel code using omp.h
Paweł Kuczyński
kuczmas is on a distinguished road
Dear forumers,
I want to compile a code that incorporates omp.h library. This library uses '#pragma' statements in order to inform the compiler about the parallel parts of the code. So the if I compile the file test.cpp using g++ I have to put a flag '-fopenmp':
g++ test.cpp -fopenmp
Is it possible to set the '-fopenmp' flag in wmake? If yes, how to do it?
Any help will be greatly appreciated.
Best regards
P. Kuczynski.
kuczmas is offline   Reply With Quote
Old   May 15, 2014, 17:00
Retired Super Moderator
Bruno Santos
Greetings Paweł,
I got the PM you sent me. The quick answer is: have a look into the files located at "wmake/rules/linux*Gcc/c*".
Problem is that editing those files will affect the whole building process. I'll try to have a better look into this during the coming weekend.
Best regards,
Bruno
Old   May 17, 2014, 17:23
Bruno Santos
Hi Paweł,
OK, I've finally managed to have a look into this. The files I looked at were:
  • "wmake/Makefile"
  • "wmake/rules/General/standard"
  • "wmake/rules/linux64Gcc/c++"
  • Then the "Make/options" and "blockMeshApp.dep" files for the blockMesh application source code.
What I could figure out is that you can edit the file "Make/options" for your application and add this line to the beginning or end of that file:
ptFLAGS += -fopenmp
Best regards,
Bruno
Last edited by wyldckat; May 17, 2014 at 17:29. Reason: mistakenly posted without finishing the post
Old   May 19, 2014, 05:15
Paweł Kuczyński
Hi Bruno,
tanks a lot for your quick and precise answer. It saved me a lot of time!
My model is added to OF in the form of separate dynamic library - where I would like to include parallel parts of the code. So I think it should be enough to compile only my library with -fopenmp flag and then use it normally inside the OF.
Many thanks!
Best regards
P. Kuczynski.
compile, omp, parallel, wmake
[OpenFOAM.com] erros in Allwmake jiwon OpenFOAM Installation 7 December 30, 2015 13:34
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 11:20
