alphaEqn.H in compressibleTwoPhaseEulerFoam OpenFoam 2.2 |
May 8, 2014, 10:49 |
simone colucci
Rep Power: 12 |
I'm working with compressibleTwoPhaseEulerFoam, I have a few questions about the continuity equation in alphaEqn.H. Consider the continuity equation as written, for example, in the thesis of Ghione 'Development and validation of a two phase CFD model using OpenFoam', eq. 2.11. - In alphaEqn.H the are two source terms Sp and Su. Considering the equation in 2.11 I expect someting like : Sp + Su = -alpha1 div(U) + alpha2 alpha1[1/rho1 Drho1/dt + 1/rho2 Drho2/dt] In alphaEqn.H Sp and Su are written as a function of dgdt, where in CreateFields.H volScalarField dgdt ( pos(alpha2)*fvc::div(phi)/max(alpha2, scalar(0.0001)) ); while in PEqn.H dgdt = ( pos(alpha2)*(pEqnComp2 & p)/rho2 - pos(alpha1)*(pEqnComp1 & p)/rho1 ); If I combine Sp+Su, in the first case I obtaine (this should be the case at the first call inside the pimple loop!): alpha1 div(U) + div(U) 1) What does it mean? In the continuity equation I do not see this term. in the second case, if I consider the formulation commented in alphaEqn. H ('Legacy semi-implicit and potentially unbounded...') // Legacy semi-implicit and potentially unbounded form fvScalarMatrix alpha1Eqn ( fvm::ddt(alpha1) + fvm::div(phic, alpha1, alphaScheme) + fvm::div ( -fvc::flux(-phir, alpha2, alpharScheme), alpha1, alpharScheme ) == fvm::Sp(Sp, alpha1) + Su ); and I do not consider & p in dgdt, I obtain the term -alpha1 div(U) + alpha2 alpha1[1/rho1 Drho1/dt + 1/rho2 Drho2/dt] that fits with the equation 2.11. 2) Why & p in dgdt? Is it the inner product, right? Considering 2.11 I do not need this product. 3) How does the uncommented formulation work? I do not see something like Sp(Sp, alpha1) + Su, but only Sp + Su. Thank you in advance Simone |
April 29, 2015, 06:28 |
Dongyue Li
Rep Power: 18 |
Ciao simone!
Point 2 is because that pEqnComp1 is defined as tmp<fvScalarMatrix>, u can use pEqnComp1 to call matrix, also u can use pEqnComp1 & p to call some real value. I mean we define U matrix like this: Code:
fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); This is my thought I'm not sure. lol Best, |
timeVaryingMappedFixedValue with OpenFOAM 2.2 | hfs | OpenFOAM Pre-Processing | 6 | May 22, 2014 04:48 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 12:32 |
Summer School on Numerical Modelling and OpenFOAM | hjasak | OpenFOAM | 5 | October 12, 2008 14:14 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 22:07 |
