"Calculate the relative velocity used to map the relative flux phi" in interDyMFoam
Old   April 29, 2014, 06:37
Post "Calculate the relative velocity used to map the relative flux phi" in interDyMFoam
xuhe-openfoam
bieshuxuhe is on a distinguished road
hi !
In openfoam-2.2.0 interDyMFoam solver , there is a piece of code that
    while (runTime.run())
        #include "readControls.H"
        #include "alphaCourantNo.H"
        #include "CourantNo.H"
        #include "setDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        scalar timeBeforeMeshUpdate = runTime.elapsedCpuTime();
            // Calculate the relative velocity used to map the relative flux phi
            volVectorField Urel("Urel", U);
            if (mesh.moving())
                Urel -= fvc::reconstruct(fvc::meshPhi(U));
            // Do any mesh changes
            mesh.update();
        if (mesh.changing())
            Info<< "Execution time for mesh.update() = "
                << runTime.elapsedCpuTime() - timeBeforeMeshUpdate
                << " s" << endl;
            gh = g & mesh.C();
            ghf = g & mesh.Cf();
        if (mesh.changing() && correctPhi)
            #include "correctPhi.H"
        if (mesh.changing() && checkMeshCourantNo)
            #include "meshCourantNo.H"
        twoPhaseProperties.correct();
        #include "alphaEqnSubCycle.H"
        interface.correct();
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
The red part code create a Urel , and it means "Calculate the relative velocity used to map the relative flux phi" . But the Urel does not appear again after the code "Urel -= fvc::reconstruct(fvc::meshPhi(U));" ! It is even not written or used , so the relative velocity Urel looks no use in this solver ! If we comment out the red part code , the solver will work well too . (I have tried.)
I am a little confused . I wonder where is Urel used to map the relative flux phi ? executing mapFields ? or we must use it ourselves by adding some lines of code in the solver ?
could you help me ?
bieshuxuhe is offline   Reply With Quote
relative flux phi
relative velocity vectors carno FLUENT 0 May 9, 2008 07:59
Mass Flux vs Velocity Inlet Sandra FLUENT 5 July 20, 2005 14:09
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Relative velocity errors in cylindrical coords? John FLUENT 0 April 5, 2000 08:46
