How to write fluctuating velocity field at runtime?
Old   April 22, 2014, 10:53
Default How to write fluctuating velocity field at runtime?
Huang Xianbei
huangxianbei is on a distinguished road
Hi,all
I'm doing a LES simulation. And I want to write the fluctuating velocity, that is:
u'=U-UMean, so how can I implement this? I tried like this
Info<< "Reading field UMean\n" << endl;
    volVectorField UMean
        IOobject
            "UMean",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
        mesh
    volVectorField Ufluc
        IOobject
            "Ufluc",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh
    Ufluc=U-UMean;
    Ufluc.write();
However, when calculate, error occurs
NO_READ specified for read-constructor of object Ufluc of class IOobject
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 46.
FOAM aborting
can anyone help?
huangxianbei is offline   Reply With Quote
Old   April 22, 2014, 11:10
Huang Xianbei
The innovation to do this is to define the fluctuating field as to do post-process about u', although I know it's possible to do U-UMean in post-process, I still want to know if this can be accomplished directly.
Old   April 27, 2014, 11:10
Tomislav Maric
tomislav_maric is on a distinguished road
You have specified the the Ufluc field not to be read from a file, and have failed to provide initial values that are in that case required to construct the field:
    IOobject
        "Ufluc",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    mesh // Missing initial values
If you don't want to provide the field in the '0' directory as a file to be read at run-time, you have to provide the default initialization argument:
     IOobject
         "Ufluc",
         runTime.timeName(),
         mesh,
           IOobject::NO_READ,
     mesh,
       dimensionedVector
           "zero",
           U.dimensions(), // Or Umean.dimensions()
           vector (0,0,0)
Also, don't use the 'regIOobject::write()' inherited member function of a field to do the writing - this will write the field every time step and will probably mess up the case. Writing should be taken care of by the 'Time' class, with:
runTime.write();
This way it won't happen for example that you output 'Ufluc' every time step, and 'U' and 'Umean' every 10th time step.
When asking a question, prepare a SSCCE.
Last edited by tomislav_maric; April 27, 2014 at 11:14. Reason: code formatting was messed up
tomislav_maric is offline   Reply With Quote
Old   April 28, 2014, 08:14
Huang Xianbei
    IOobject
        "Ufluc",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
     IOobject
         "Ufluc",
         runTime.timeName(),
         mesh,
           IOobject::NO_READ,
     mesh,
       dimensionedVector
           "zero",
           vector (0,0,0)
runTime.write();
Hi,Tomislav:
Thank you for your reply. Where should I put the 'runTime.write()' as you say? .H file or in the .C file?
Old   April 29, 2014, 05:41
Tomislav Maric
[QUOTE]
[\QUOTE]
'runTime' is a global object (class 'Foam::Time'), and it's usually used in application (solver) client code - if you open a solver you are interested in, you will find it at the end of the main simulation loop.
If you are doing modifications in createFields.H, you don't have to explicitly write the fields there with '.write()', the solver will take care of the writing of all registered fields.
Old   April 29, 2014, 22:41
Huang Xianbei
[QUOTE=tomislav_maric;488832]
[\QUOTE]
Oh,that's to say, I don't need to do with the '.write' since the solver has already done this. The only thing is to create the filed I need.
A Question About Setting Whole Velocity Field Using "Proflie" in FLUENT adsl17754 FLUENT 5 July 31, 2018 05:29
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Setting the Velocity Field Adammann OpenFOAM 1 July 8, 2011 03:15
transient temperature field with constant velocity Törnquist CFX 0 September 16, 2003 05:22
Pressure from velocity field Svante Hellzén Main CFD Forum 5 November 30, 1999 19:20
