runTimeSelection of viscosityModels in pimpleFoam !
Old   April 18, 2014, 00:12
Post runTimeSelection of viscosityModels in pimpleFoam !
xuhe-openfoam
bieshuxuhe is on a distinguished road
hi !
In pimpleFoam/createFields.H , there is a line of code :
singlePhaseTransportModel laminarTransport(U, phi);
I think that code means reading transportProperties ! So I check it in the source guide , there is :
31 // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
32
33 Foam::singlePhaseTransportModel::singlePhaseTransportModel
34 (
35  const volVectorField& U,
36  const surfaceScalarField& phi
37 )
38 :
39  transportModel(U, phi),
40  viscosityModelPtr_(viscosityModel::New("nu", *this, U, phi))
41 {}
42
32
33 Foam::transportModel::transportModel
34 (
37 )
38 :
39  IOdictionary
40  (
41  IOobject
42  (
43  "transportProperties",
44  U.time().constant(),
45  U.db(),
46  IOobject::MUST_READ_IF_MODIFIED,
47  IOobject::NO_WRITE
48  )
49  )
50 {}
please note the red "*this" , "this" pointer should point to the object of "singlePhaseTransportModel class" ! so the "*this" is the laminarTransport ,but the New() function need a dictionary not a singlePhaseTransportModel ! look down the code:
Foam::autoPtr<Foam::viscosityModel> Foam::viscosityModel::New
    const word& name,
    const dictionary& viscosityProperties,
    const word modelType(viscosityProperties.lookup("transportModel"));
    Info<< "Selecting incompressible transport model " << modelType << endl;
    dictionaryConstructorTable::iterator cstrIter =
        dictionaryConstructorTablePtr_->find(modelType);
    if (cstrIter == dictionaryConstructorTablePtr_->end())
        FatalErrorIn
            "viscosityModel::New(const volVectorField&, "
            "const surfaceScalarField&)"
        )   << "Unknown viscosityModel type "
            << modelType << nl << nl
            << "Valid viscosityModels are : " << endl
            << dictionaryConstructorTablePtr_->sortedToc()
            << exit(FatalError);
    return autoPtr<viscosityModel>
        (cstrIter()(name, viscosityProperties, U, phi));
I know that the singlePhaseTransportModel is a multiplely derived class from dictionary class ! is it why we can regard singlePhaseTransportModel as a dictionary when using New()?
thanks!
bieshuxuhe is offline   Reply With Quote
Old   April 18, 2014, 02:30
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Yes.
class transportModel
    public IOdictionary
    IOdictionary
        IOobject
            U.db(),
            IOobject::NO_WRITE
alexeym is offline   Reply With Quote
Old   April 18, 2014, 03:08
xuhe-openfoam
Thanks for your reply !
runTimeSelection mechanism is so beautiful !
so is the objectRegistry.
Old   August 4, 2015, 20:45
Default transportmodel
jafar
bagherij is on a distinguished road
Hi
I am working on creeping flow (non- Newtonian steady),i used simple foam with a viscosity model ,i need to use kinematic viscosity
(nu(), which returned from viscosity model) to calculate shear stress ,how can i use nu in a utility or a function?i modify the utility "stresscomponent.C" as follow but this message coming
"nu is not declared in this scope"
code:
#include "fvCFD.H"
#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
#include "zeroGradientFvPatchFields.H"
int main(int argc, char *argv[])
timeSelector::addOptions();
# include "setRootCase.H"
# include "createTime.H"
instantList timeDirs = timeSelector::select0(runTime, args);
# include "createMesh.H"
forAll(timeDirs, timeI)
runTime.setTime(timeDirs[timeI], timeI);
Info<< "Time = " << runTime.timeName() << endl;
IOobject Uheader
"U",
runTime.timeName(),
mesh,
IOobject::MUST_READ
// Check U exists
if (Uheader.headerOk())
mesh.readUpdate();
Info<< " Reading U" << endl;
volVectorField U(Uheader, mesh);
# include "createPhi.H"
volScalarField strainRate
IOobject
"strainRate",
runTime.timeName(),
mesh,
IOobject::NO_READ
nu()*sqrt(2.0f)*mag(symm(fvc::gra d(U))) //this command will calculate strainRate
strainRate.write();//this will write file "StrainRate" in each time dir!!
else
Info<< " No U" << endl;
Info<< endl;
Info<< "End" << endl;
return 0;
best regards
jafar
bagherij is offline   Reply With Quote
runtimeselection
Running stably with a large Courant number using pimpleFoam mlawson OpenFOAM 11 November 29, 2014 11:37
pimpleFoam initialization? TBERGE OpenFOAM Running, Solving & CFD 2 April 2, 2014 09:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Understanding pimpleFoam convergence criterion Nucleophobe OpenFOAM Running, Solving & CFD 0 March 13, 2013 19:46
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H uli OpenFOAM Programming & Development 7 January 26, 2013 16:01
