April 15, 2014, 02:21 |
How to access protected variable?
Manjunath Reddy
Rep Power: 13 |
Hiiii,
While making Ldumatrix.C in which is in test folder. I'm getting error with this lines UEqnp.addBoundaryDiag(U3Eqnp.diag(), 0); UEqnp.addBoundarySource(U3Eqnp.source(), false); That is /opt/openfoam222/src/finiteVolume/lnInclude/fvMatrix.C:150:6: error: ‘void Foam::fvMatrix<Type>::addBoundarySource(Foam::Fiel d<Type>&, bool) const [with Type = Foam::Vector<double>]’ is protected which is showing addBoundarySource is protected how to access that please help me... Regards Manjunath |
October 22, 2015, 08:05 |
#2 | |
Rep Power: 11 |
Hi Manjunath,
I have the same problem when accessing protected variables with addBoundaryDiag and addBoundarySource. Did you find any information on how to solve it? Regards, --CME Quote:
October 22, 2015, 10:06 |
#3 | |
Matvey Kraposhin
Rep Power: 21 |
Or 2) Create a nested class which inherits base class (fvMatrix)
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
October 22, 2015, 10:31 |
#4 | ||
Rep Power: 11 |
Undortunately, my minimal C++ skills are not enopugh to understand it. For this very simple example that does not compile Quote:
Thanks in advance for youe help. Regards, --Carlos |
October 22, 2015, 10:51 |
#5 | |||
Matvey Kraposhin
Rep Power: 21 |
In both cases it is not a trivial task:
1) In the first case you must declare any some function like Quote:
2) In the second case you can use inheritace mechanism: Quote:
Any way, you will need a good knowledge of C++
October 22, 2015, 11:17 |
Rep Power: 11 |
thanks again mkraposhin
How access member variable of a boundary condition | Vesposo | OpenFOAM Programming & Development | 1 | March 13, 2014 08:49 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Error: access: unbound variable | cfd-novice | FLUENT | 0 | April 3, 2003 05:53 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
