dimension [0 0 -0 0 0 0 0]?
Old   April 10, 2014, 00:49
Default dimension [0 0 -0 0 0 0 0]?
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
I have a volScalarField,
volScalarField epsilonD(pow(epsilon/pow(d,2),1/3));
you can see that epsilon's dimension is [0 2 -3 0 0 0 0] and d's dimension is [0 1 0 0 0 0 0], So epsilonD's dimension should be [0 0 -1 0 0 0 0]
But openfoam tell me its dimention is [0 0 -0 0 0 0 0]?
Any ideas?
sharonyue is offline   Reply With Quote
Old   April 10, 2014, 00:56
Dongyue Li
volScalarField epsilonD(pow(epsilonF,1/3));
This is very simple, epsilonF's dimension is [0 0 -3 0 0 0 0] , but epsilonD's dimention is [0 0 -0 0 0 0 0]
Old   April 10, 2014, 04:16
Dongyue Li
Solved.
volScalarField epsilonD(pow(epsilonF,1.0/3.0));
I checked it out in dimensionSet.C and I got this piece of code:
Foam::dimensionSet Foam::cbrt(const dimensionSet& ds)
    return pow(ds, 1.0/3.0);
Foam::dimensionSet Foam::pow(const dimensionSet& ds, const scalar p)
    dimensionSet dimPow
        ds[dimensionSet::MASS]*p,
        ds[dimensionSet::LENGTH]*p,
        ds[dimensionSet::TIME]*p,
        ds[dimensionSet::TEMPERATURE]*p,
        ds[dimensionSet::MOLES]*p,
        ds[dimensionSet::CURRENT]*p,
        ds[dimensionSet::LUMINOUS_INTENSITY]*p
    return dimPow;
I dont know if its a bug. But its solved right now. Any comments are welcomed.
Old   April 10, 2014, 04:38
xuhe-openfoam
bieshuxuhe is on a distinguished road
int a=1;
int b=3;
float c=a/b;
when a and b both are int, c=0
best wishes!
bieshuxuhe is offline   Reply With Quote
How to get a single value from a volScalarField including the dimension safre OpenFOAM Programming & Development 18 May 20, 2016 09:01
Dimension of pressure: M/LT2 or L2/T2? gcengineer OpenFOAM Running, Solving & CFD 6 August 7, 2013 17:41
ANSYS Fluent 14.0, dimension problem? SteveFinnan ANSYS 2 June 14, 2013 10:12
the problem about dimension bojiezhang OpenFOAM 2 October 16, 2011 01:22
Dimension problem faroque OpenFOAM Running, Solving & CFD 5 February 19, 2008 09:56
