April 9, 2014, 03:26 |
ITK in OpenFOAM
Rep Power: 13 |
How can I interlace my own OpenFOAM code with ITK?
Assume that I simply take an existing OpenFOAM code (such as icoFoam) and want to extent it using some routines for which I need to write own cpp classes. One of these cpp classes include ITK routines in order to call functions related to image processing. How do I have to change the Make/files or Make/options in order to be able to build and run all together? Checking ITK tutorials, I see that they only use cmake writing some CMakeList.txt files, so there was no example how to do it with wmake or how to bring it to run together with own OpenFOAM developments. I tried to call 'cmake' as a command in Make/files and tried to build with wmake, but no success so far. Any ideas? Many thanks. |
April 9, 2014, 10:10 |
Tomislav Maric
Rep Power: 21 |
I have encountered the same problem when I wanted to use Google Test. If you just use 'wmake' and provide the appropriate input in 'Make/options', you will be able to compile OpenFOAM applicaitons and classes against any other external library, here is what I did for Google Test: Code:
EXE_INC = \ -I$(SOME_VARIABLE)/src/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(SOME_VARIABLE)/third-party/gtest/include EXE_LIBS = \ -L$(SOME_VARIABLE)/third-party/gtest/build \ -lgtest \ -lfiniteVolume |
April 26, 2014, 12:45 |
Rep Power: 13 |
Hi there,
Thank you very much for your response! That solved the problem very well. It was a little bit hard though, since there has been too many missing libraries, certain other Unix related issues and together with very little to almost non-descriptive error messages. But after some painfully amount of days, the issue could be resolved, in the meanwhile getting to be a fully developed Unix-Freak . I can almost hack now . |
April 26, 2014, 13:28 |
Tomislav Maric
Rep Power: 21 |
Hi, I'm glad it helped!
The problem with the almost unreadable errors you probably saw yourself when libraries are not linked properly is that symbol lookups fail - the compiler tries to find a function like: Code:
void functionName(type argument, type2 argument2) Code:
undefined reference to 73Edcvoid7sesfunction2ctype13x_type2x32 @hacking: I know what you mean, it takes time to get a hang of these things, just keep digging into that stuff and post here when you encounter problems that take more than half a day to tackle...
When asking a question, prepare a SSCCE. |
April 28, 2014, 03:28 |
April 28, 2014, 06:33 |
#6 | |
Tomislav Maric
Rep Power: 21 |
What incompressible tried to do at first can't work - using two build systems. My suggestion is to use whatever build system your OpenFOAM version is using (wmake, cmake, boost.build, whatever), to build OpenFOAM applications and libraries. Likewise, one should switch to the build system of the other platform (in this case ITK) to build apps and libs that only make use of OpenFOAM headers / libraries within that platform.
April 28, 2014, 17:42 |
#7 | |
Rep Power: 13 |
In ITK, for example, they use certain design patterns whose objects are created and prepared in their certain cmake files directly. In terms of a given try to what computer scientist call "information hiding", this should happen behind the knowledge of the user or they shouldn't care about how these objects are actually created. One example of such structures are the factory classes responsible to create and manage objects to handle, lets say, different file formats such as PNG, JPEG, TIFF etc. Now, if an ITK user, whatever her own ITK application she prepares with cmake, loads a PNG image, she won't even now or realise the factory objects that does the job. As she builds her application with cmake, one of the main cmake files of ITK are called automatically, which creates these objects. However, if an OpenFOAM user, such as me, now goes forward and tries to integrate ITK platform to his OpenFOAM framework, he will just wonder why his images cannot even be loaded at all. So it is not "enough" to just put the libraries and includes to the wmake files, but all necessary factory objects now have to be created manually in own code, as long as one does not follow the path given by cmake builds. Therefore the statement with "the same idea regardless of the build system" might not always be valid, but in general of course the truth. Maybe its a little bit more clear now, why I originally tried to call something like 'cmake' from wmake with a hopeless hope to be able to build another application and dynamically link it to OpenFOAM framework without having to perform two separate builds. |
April 29, 2014, 05:24 |
#8 | |
Tomislav Maric
Rep Power: 21 |
IMHO, to me this seems like a strange approach to set up an object factory. I don't see the logical connection between the build system and the factory at all... If a generic factory is used, I would expect the client code (some ITK/OpenFOAM application cpp file) to instantiate the appropriate factory at compile time. On the other hand, if something like OpenFOAM's run-time selection is used, then the object generation will be bound to the class hierarchy and governed by configuration (input) files - are they using make files for this in ITK? Binding it to the build system just sounds a bit weird to me... but maybe it's done this way because there are no case directories like for OpenFOAM where you can then shove the input data for the run-time selection of the factory. Anyway, no wonder it took you some time to set that up. Was the factory a pointer to the base factory class in the client ITK code, and you kept getting run-time errors? Segfaults since the concrete factory is not initialized would be my first guess. That must have been 'extremely fun' to find.
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 04:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
OpenFOAM Training and Workshop | Hrvoje Jasak | Main CFD Forum | 0 | October 7, 2005 08:14 |
