GPU compilation for hybrid vortex/finite volume Method
Old   March 22, 2014, 04:38
Default GPU compilation for hybrid vortex/finite volume Method
Frivole is on a distinguished road
I am working on a hybrid vortex method/finite volume method. I already have a C++ implementation of the vortex method and I have decided to use OpenFOAM for the FVM part.
In the vortex method, to solve the N-body problem we use a GPU function. To compile it we first compile the cuda part with nvcc and then we link using g++. The makefile is:
INCLUDE = -I/opt/cuda/include -I.
LIBS = -Wl,-rpath,/opt/cuda/lib64 -L/opt/cuda/lib64 -lcuda -lcudart
CXX = g++
LD  = g++
CXXFLAGS = -O2 -Wall $(INCLUDE)
LDFLAGS = -O2
NVCC = nvcc
NVCCFLAGS = $(INCLUDE)
SRC= $(wildcard *.C)
SRCU= $(wildcard *.cu)
OBJ= $(SRC:.C=.o) $(SRCU:.cu=.o)
EXE = main
all: $(EXE)
.SUFFIXES: .cu
.cu.o:
    $(NVCC) $(NVCCFLAGS) -c $< -o $@
.C.o:
    $(CXX) $(CXXFLAGS) -c $< -o $@
main: $(OBJ)
    $(LD) $(LDFLAGS) $(OBJ) $(LIBS) -o $@
So to compile the hybrid method, I was wondering if it was possible to modify wmake to do the same thing.
Thank you
Frivole is offline   Reply With Quote
Old   March 31, 2014, 20:38
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I've only worked with cuda solvers outside of OF but the latest foam-3.0 has a few nvcc compiled linear solvers coupled with it. You might be able to get a few hints on this here:
foam-extend-3.0/src/cudaSolvers/
And the respective Allwmake, Make/options, Make/files
Cheers!
Kyle
kmooney is offline   Reply With Quote
Old   April 4, 2014, 00:05
Hi Kyle,
Thanks for your answer!!
As you suggested I looked at the foam-extend-3.0 and decided to use it.
The installation went well, however when I run the Allwmake.firstInstall I get:
Cuda compiler detected at /opt/cuda/bin/nvcc;
cudaSolvers will be compiled by default.
$CUDA_ARCH is required by nvcc compiler but not set.
Check section '-gpu-architecture' in 'man nvcc' for details.
People seems to have the same kind of issue in the thread:
extend-3.0 cuda installation
So I will try to look for a solution there.
Thanks again,
Pierre
Old   April 4, 2014, 14:31
kmooney's Avatar
Kyle Mooney
Hi Pierre,
Take a look at this file:
/foam-extend-3.0/wmake/rules/linux64Gcc/nvcc
There you can see how $CUDA_ARCH is actually added to the compiler flags. Maybe you know enough about nvcc compilers such that you know what the env variable is supposed to be set as.
Cheers!
Kyle
Old   April 7, 2014, 05:57
Hi Kyle,
I am sorry for answering so late.
In fact I had an issue with my swak4Foam, and, after reinstalling it, Allmake ran without problems. However when after I try to compile the a solver with cuda I got that kind of error :
Found nvcc  --  enabling CUDA support.
make: *** No rule to make target `fastBiot/fastBiot.dep', needed by `Make/linux64Gcc46DPOpt/dependencies'.  Stop.
make: *** Waiting for unfinished jobs....
So I copy paste the rules/linux64Gcc/nvcc file into rules/linux64Gcc46/nvcc without any success...
gpu, nvcc, vortex method, wmake
The aspect ratio of the volume elements in Finite Volume Method CharlieTan84 Main CFD Forum 3 August 28, 2012 03:34
Control volume based finite difference method? mukut.medhi Main CFD Forum 3 August 24, 2012 11:01
Help regarding implementing the Finite Volume method for meridional flows shreyasr Main CFD Forum 0 July 23, 2012 08:05
Finite Volume Method cfd seeker Main CFD Forum 3 September 8, 2011 05:36
Control Volume Finite Element Method gerardosrez Main CFD Forum 0 March 16, 2011 15:49
