March 19, 2014, 09:21 |
generally defined boundary conditions
Illya Shevchuk
Rep Power: 17 |
Hi foamers,
Following problem: I want to create a volScalarField with a given boundary condition on all the boundaries of this field. The implementation should be general and valid regardless of the number and the type of the boundaries defined elsewhere. Here's an example. In createFields.H I want to create a field someField with boundaries Code:
{ type fixedValue; value uniform 0; } Code:
volScalarField someField ( IOobject ( "someField", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar("someField", dimensionSet(0,1,0,0,0,0,0), 0.0), ???? boundaries ???? ); |
March 21, 2014, 18:48 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Linch,
Replacing the red text with Code:
"fixedValue" Good luck, Nield
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
Export boundary setting in Fluent 14.0 | asal | FLUENT | 4 | September 28, 2017 10:40 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Fluent accuracy and boundary conditions | Paolo Lampitella | FLUENT | 0 | June 12, 2008 07:25 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 19:29 |
