check in a uniformInterpolationTable without destroying it |
March 13, 2014, 09:29 |
Rep Power: 13 |
in the constructor of my boundary condition I'm trying to construct an uniformInterpolationTable and check it into the objectRegistry. Code:
myUniformInterpolationTable_ ( IOobject ( tableName_, this->patch().boundaryMesh().mesh().time().constant(), this->patch().boundaryMesh().mesh(), IOobject::MUST_READ, IOobject::NO_WRITE, true ), true ) Code:
const uniformInterpolationTable<scalar>& myTable = db().lookupObject<uniformInterpolationTable<scalar> >(tableName_); Code:
--> FOAM FATAL ERROR: request for IOobject myUniformInterpolationTable_ from objectRegistry region0 failed available objects of type IOobject are 0() Code:
Constructing IOobject called myUniformInterpolationTable_ of type IOobject objectRegistry::checkIn(regIOobject&) : region0 : checking in myUniformInterpolationTable_ Destroying regIOobject called myUniformInterpolationTable_ of type regIOobject in directory Thanks |
March 13, 2014, 14:45 |
Marco A. Turcios
Rep Power: 28 |
Are you sure you are checking it in to the object registry with the call to this->patch().boundaryMesh().mesh()? Following the function calls seems like you're returning pointers and references. Can you try use a more direct access to mesh and see if it improves things?
March 14, 2014, 03:38 |
#3 | |
Rep Power: 13 |
The debug information says Code:
objectRegistry::checkIn(regIOobject&) : region0 : checking in myUniformInterpolationTable_ I don't know how to access it in a more direct way, due to I'm in my boundary condition. Can you give me a hint. Thanks |
March 14, 2014, 12:39 |
Marco A. Turcios
Rep Power: 28 |
If its checking in and then out, then maybe its more the time you are asking it to be created. Try this->db().time().constant(). It seems most boundary conditions use that for finding the time. Similarly, maybe try this->db().mesh().
Mesh check failed | subhas.hunasikatti@gmail. | FLUENT | 0 | January 19, 2014 05:09 |
[ICEM] Understanding check mesh output | kotimari | ANSYS Meshing & Geometry | 0 | July 15, 2012 09:33 |
faceZones and topological check | mturcios777 | OpenFOAM Programming & Development | 0 | June 15, 2012 14:48 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
Cell check and Boundary check errors | AB | Siemens | 4 | October 28, 2004 14:04 |
