Calculations and Dimensions
Old   March 6, 2014, 09:04
Default Calculations and Dimensions
maybee is on a distinguished road
I am working with the multiphaseEulerFoam and I recognized that sometimes fields are initialized like
volScalarField p
        IOobject
            "p",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
without getting dimensions. On the other hand some fields are initialized like
volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
        mesh,
        dimensionedVector("U", dimVelocity, vector::zero)
Should I initialize fields generally with a dimensioned type especially when using them for calculations or should I initialize fields without any dimension type (-> are they dimless then?) ?
maybee is offline   Reply With Quote
Old   March 6, 2014, 09:23
Lieven
Lieven will become famous soon enough
Hi Maybee,
The clue is in the way the field is read:
In case of your 'p'-example, the p-field must be read (IOobject::MUST_READ). Initial value of the field and also the dimensions are read from the field in the time folder "runTime.timeName()".
In case of the velocity field U. You specify IOobject::NO_READ meaning that OF will not search for an input file in the time folder but that the field is initialized by the dimensions vector (which automatically defines the dimensions).
There is an other option possible: READ_IF_PRESENT which basically combines the two previous ones. (in fact also a fourth, MUST_READ_IF_MODIFIED, but this is less relevant in the present context).
Hope this clarifies things...
Cheers,
L
Lieven is offline   Reply With Quote
Old   March 6, 2014, 13:09
Thx. got it now.
Old   December 26, 2014, 08:06
Niu
Z.Q. Niu is on a distinguished road
Hi Lieven, I want to define volSymmetryField, but I don't know know how to write the code of demensioneSet and initialize it. Would you mind giving me some advice? Thanks!
Z.Q. Niu is offline   Reply With Quote
transient calculations! lelia Siemens 9 April 14, 2008 09:33
How to choose a BL dimensions..? Cyril FLUENT 11 September 21, 2007 09:42
Including gravity in calculations!!! gilberto CFX 26 October 15, 2001 21:55
