Error: problem with wordlist
Old   March 5, 2014, 10:20
Default Error: problem with wordlist
maybee is on a distinguished road
hi,
I have about the following code:
wordList MyList  //works fine
         properties.lookup("MyListe")
wordlist Names (fluid.phases().toc());  //does not work - error
                                     //fluid.phases() returns a PtrDictionary<phaseModel> and toc() a wordlist
Unfortunately I get an error for the second wordlist shown above:
Values.H: In function ‘int main(int, char**)’:
Values.H:110:1: error: ‘wordlist’ was not declared in this scope
Values.H:110:10: error: expected ‘;’ before ‘Names’
Values.H:111:18: error: ‘Names’ was not declared in this scope
What am I doing wrong here?
maybee is offline   Reply With Quote
Old   March 5, 2014, 10:39
Ok, got it
wordList ≠ wordlist
Help with if statement CHARLES OpenFOAM Programming & Development 17 August 22, 2021 04:14
adding compressible option to ptot immortality OpenFOAM Programming & Development 13 June 15, 2015 16:00
Initialize a volScalarFiedl with wordList of patch types tgillebaart OpenFOAM Programming & Development 0 February 9, 2011 09:34
add entry to wordList peterwy OpenFOAM Programming & Development 3 October 4, 2010 08:13
FoamToVtk syntax for fields tehache OpenFOAM Post-Processing 1 October 10, 2007 11:29
