February 28, 2014, 10:30 |
Modified Atmospheric Boundary Layer BC
ashwin
Rep Power: 14 |
Hello Everybody,
I have modified the atmBoundaryLayerInletVelocity Boundary Condition to a customFvPatch Boundary condition (which is Attached). It is compiled and does not give any errors. However when I try to use it after updating my ControlDict. It gives me the following error. Code:
--> FOAM FATAL IO ERROR: Unknown patchField type custom for patch type patch Valid patchField types are : 68 ( SRFFreestreamVelocity SRFVelocity activeBaffleVelocity activePressureForceBaffleVelocity advective atmBoundaryLayerInletVelocity calculated codedFixedValue codedMixed cyclic cyclicAMI cyclicSlip cylindricalInletVelocity directionMixed empty externalCoupled fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedNormalSlip fixedValue flowRateInletVelocity fluxCorrectedVelocity freestream inletOutlet kqRWallFunction mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mappedFlowRate mappedVelocityFlux mixed movingWallVelocity nonuniformTransformCyclic oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip pressureDirectedInletOutletVelocity pressureDirectedInletVelocity pressureInletOutletParSlipVelocity pressureInletOutletVelocity pressureInletUniformVelocity pressureInletVelocity pressureNormalInletOutletVelocity processor processorCyclic rotatingPressureInletOutletVelocity rotatingWallVelocity sliced slip supersonicFreestream surfaceNormalFixedValue swirlFlowRateInletVelocity symmetryPlane timeVaryingMappedFixedValue translatingWallVelocity turbulentInlet uniformFixedValue uniformJump uniformJumpAMI variableHeightFlowRateInletVelocity waveTransmissive wedge zeroGradient ) Regards Ashwin |
March 5, 2014, 07:15 |
Srivathsan N
Rep Power: 13 |
From the error you've posted it is seen that the patch doesn't recognise the boundary condition. Check if you've updated the Make/files files in the location where you've defined the boundary condition and give 'wmake' again. Since you have already added libcustomFvPatchField.so to the controlDict it should recognise the BC.
Regards, Srivaths |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Atmospheric boundary layer | Daniele111 | OpenFOAM Running, Solving & CFD | 50 | November 3, 2023 04:22 |
Atmospheric Boundary Layer high turbulent flow | Bollonga | FLUENT | 3 | March 12, 2019 12:17 |
Simulation of atmospheric boundary layer | Bazinga | OpenFOAM Pre-Processing | 1 | February 19, 2014 14:15 |
Atmospheric boundary layer simulation | samygero | Main CFD Forum | 0 | March 22, 2011 10:36 |
