February 26, 2014, 10:25 |
Solving simultaneous PDE's in OpenFOAM
Manjunath Reddy
Rep Power: 13 |
Hiiiii,
I'm working on Simulation of two phase immscible flow through porous media. I've oil-water equations to be solved. Oil equation: - fvm::ddt(por,sw) + fvm::Sp(J*n*M_o,p) - fvm::laplacian(phik*phiM_o,p) == - fvc::laplacian(phiM_o*phik*rho_o,gh) + fvc::Sp(J*n*M_o,pbh) Similarly i've equation for water. I want to solve two equations simultaneously. how to solve equations simultaneously by using "solve" . Can any one help how to proceed. Thanks & Regards N.Manjunath Last edited by manju819; February 26, 2014 at 13:19. |
April 12, 2020, 17:43 |
#2 | |
Russian Federation
Rep Power: 6 |
Did you solve this problem? I deal with the same one. |
April 16, 2020, 06:02 |
Michael Alletto
Rep Power: 16 |
as far as I know, there only possibility to solve two equations at the time, is to use the block coupled solver in foam-extend. The .com and .org versions use solvers for scalars. Even the velocity is solve sequentially.
https://foam-extend.fsb.hr/wp-conten..._20Sep2018.pdf |
fvmatrix, solvecoupled |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
rhoSimplecFoam Mach0.8 no pressure values | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 16 | November 23, 2013 05:58 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
