Solid body motion in a channel
Old   February 16, 2014, 15:16
Default Solid body motion in a channel
rafab is on a distinguished road
I need some general advice or approach to the following task:
My task is to simulate transport of a small steel wire inside a vertical channel.
The steel wire should be carried by the upwards flow, highly turbulent, and then captured by a filter located in the upper part of the channel.
Since I cannot treat this steel wire as a particle (it's neither spherical nor smaller than the size of a mesh cell) pure particle tracking methodology is not suitable.
Is there any way to tackle this without rebuilding existing or creating a new solver?
Thank you in advance
rafab is offline   Reply With Quote
Old   February 16, 2014, 16:50
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening,
I do not know, how the following method works for particles larger than the grid cells, but it might be worthwhile to look at:
http://www.cfdem.com/non-spherical-particles
At least at inspiration.
The following link, however, seems to be quite close to what you need:
https://www.google.nl/url?sa=t&sourc...lZvranO8eZjwcg
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   February 16, 2014, 17:30
Thank you for your interest,
I've come across with Jelena Andric's thesis already it's a nice work and might be useful for me as well.
I had the same idea to build a solid body with small spheres, maybe I will give a try first to this. Thanks for the link
deposition, solid body, tracking, transport
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Rigid body motion - Translation and Rotation dsk2 STAR-CCM+ 1 February 4, 2014 12:01
Accelerated Body Motion Simulation reza1111 Main CFD Forum 2 June 3, 2013 10:00
rigid body motion antonello FLUENT 3 July 28, 2004 04:25
Motion of sphere freely suspended in channel flow faithkim Main CFD Forum 1 August 12, 1999 11:42
