Debugging with Eclipse (gdb7.x bug)
Old   February 11, 2014, 07:18
Default Debugging with Eclipse (gdb7.x bug)
hajott is on a distinguished road
I am trying to debug an OpenFOAM solver. I am using gdb-7.6.1 on the commandline without any problems.
I would like to use the Eclipse debugger as mentioned here:
http://openfoamwiki.net/index.php/Ho..._and_debugging
Unfortunately the debugger freezes, when controlled through Eclipse. The Wiki says "Please be careful choosing the right gdb version! In gdb 7.x a bug seems to occur while debugging and monitoring the variables." (http://openfoamwiki.net/index.php/Ho...lipse#Versions)
Have you been successful when debugging OpenFOAM with Eclipse?
Is it possible to use an older gdb version (gdb-6.8 as recommended in the Wiki) next to a recent gcc installation?
Regards
hajott is offline   Reply With Quote
Old   February 17, 2014, 06:11
Is nobody debugging OpenFOAM with Eclipse?
Old   February 17, 2014, 09:37
Retired Super Moderator
Bruno Santos
Quick answer - There are at least 2 threads on this topic:
  1. http://www.cfd-online.com/Forums/ope...-openfoam.html
  2. http://www.cfd-online.com/Forums/ope...se-kepler.html
Have you read them?
Old   February 18, 2014, 04:53
Thank you. I hadn't read this one. I'll ask again in this thread.
This one is not (yet) about the gdb problems:
Old   February 18, 2014, 06:36
Bruno Santos
Sorry about that... I always associate problems with Eclipse to GDB
debug, eclipse, gdb
gdbOF: A debugging Tool for OpenFOAM nisi OpenFOAM Announcements from Other Sources 18 August 20, 2015 12:43
OpenFoam 2.X and Eclipse Kepler x86_64leon OpenFOAM Programming & Development 14 September 6, 2014 20:28
OpenFoam & Eclipse gary7 OpenFOAM Programming & Development 4 March 19, 2012 12:29
Debugging in Eclipse carowjp OpenFOAM Programming & Development 1 October 1, 2011 17:06
OpenFOAM + Eclipse Svensson OpenFOAM 2 April 10, 2011 12:02
