Randal Samstag
Rep Power: 12 ![]() |
I am a new user of OpenFOAM but very familiar with CFD for settling problems. I have written my own 2D Fortran code for this problem solving the flow field using a Patankar scheme with a k-epsilon turbulence model. The solids settling and transport in this code are handled using a two-way (density-coupled) scalar transport equation, rather than a two-fluid approach. I am trying to develop some understanding of the settlingFoam tutorial. I have been able to run both the 2D and 3D versions of this and view the results in paraView. I don't see any indication of solids concentrations in the paraView displays. My understanding was that this code was "multi-phase". All I see in the paraView parameters is velocity, no solids. I would love to communicate with someone who is expert in this code, preferably the developer. Please reply here if you can help.
Rep Power: 0 ![]() |
Hi Randal.
Did you see the Daniel Brennan's thesis? Is not difficult to found. Look chapters 6.4 (Dahl) and 7 (tank3D). I think alfa is fraction of solids. Greetings. |
Randal Samstag
Posso,
Thanks so much. Yes, I had seen Brennan's thesis. It doesn't say a word about OpenFOAM. I have finally figured out how to display solids as "alpha" in ParaView. Little steps for little feet. Regards, Randal |
Niels Gjoel Jacobsen
Rep Power: 37 ![]() ![]() |
Good morning Randal,
The code was still called FOAM back then, and that name is mentioned in the acknowledgement. Good luck, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
Randal Samstag
Niels,
You are quite right, and "settlingFoam" is mentioned (once) in the text. Thanks. Randal |
settlingfoam |
How to add Exner equation in settlingFoam | jimbean | OpenFOAM Running, Solving & CFD | 1 | October 6, 2013 09:59 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 03:24 |
Unrealistic pressure drop in settlingFoam | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 1 | February 2, 2012 04:56 |
transportProperties settlingFoam | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 3 | December 23, 2011 07:44 |
Diffrence in SettlingFoam 1.5 & 1.6 | pramodopen4foam | OpenFOAM | 0 | November 6, 2009 05:15 |
