Dimensioned Scalar Help
Old   January 8, 2014, 14:22
Default Dimensioned Scalar Help
physics1 is on a distinguished road
I am solving a transport equation ddt(n)+div(n,U)=0 for a ciruclar density area. As it transport the density begins to break up. We have fixed this by inputing a diffusion coefficient into the equation making it ddt(n)+div(n,u)-k*laplacian(n)=0, where k is defined as a dimensioned scalar. The issue is that at k=10,000 the diffusion works and the density does not break up but if i increase it to k=100,000 the density structures again. Ive compared it to the case where k=0 and they look identical. Is there a maximum value for a dimensioned scalar that i am hitting when i increase k from 10,000 to 100,000? If so how can i make that value larger?
physics1 is offline   Reply With Quote
Old   January 9, 2014, 03:23
Bernhard
Bernhard is on a distinguished road
ddt(n)+div(n,U) is not the way to implement a scalar transport equation in OpenFOAM. You would need ddt(n)+(phi,n). Have a look at the scalarTransportFoam solver.
Bernhard is offline   Reply With Quote
Old   January 9, 2014, 12:34
The transport equation is working correctly (i just mistyped it) i just need help with understanding what a dimensioned scalar is. It seems like im maxing out the value possible for a dimensioned scalar since it works for 10000 but not 100000.
dimensionedscalar
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
FATAL ERROR:Maximum number of iterations exceeded zqlhzx OpenFOAM Running, Solving & CFD 4 July 13, 2016 16:53
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 24, 2014 00:48
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
