conjugate boundary condition
Old   December 31, 2013, 14:11
Default conjugate boundary condition
Daniel
Daniel_Khazaei will become famous soon enough
Hello foamers
I have a question about conjugate boundary condition at fluid-solid interface.
1) Can someone here explain the theory behind this boundary condition or point me to a proper reference regarding this type of boundary condition?
2) Also I know there is a boundary condition called "solidWallMixedTemperatureCoupled" which can be used in these situations, but for some reason I do not want to use this boundary condition in my code. Furthermore, in 1.6ext this boundary condition only works on conformal meshes. (interpolation method)
I have gone through the source code of this boundary condition, but there is a part that I do not understand:
This part in member function updateCoeffs():
    // Swap to obtain full local values of neighbour internal field
    scalarField nbrIntFld = nbrField.patchInternalField();
    mapDistribute::distribute
        Pstream::defaultCommsType,
        distMap.schedule(),
        distMap.constructSize(),
        distMap.subMap(),           // what to send
        distMap.constructMap(),     // what to receive
        nbrIntFld
    // Swap to obtain full local values of neighbour K*delta
    scalarField nbrKDelta = nbrField.K()*nbrPatch.deltaCoeffs();
        distMap.schedule(),
        nbrKDelta
void Foam::solidWallMixedTemperatureCoupledFvPatchScalarField::updateCoeffs()
    if (updated())
        return;
    // Get the coupling information from the directMappedPatchBase
    const directMappedPatchBase& mpp = refCast<const directMappedPatchBase>
        patch().patch()
    const polyMesh& nbrMesh = mpp.sampleMesh();
    const fvPatch& nbrPatch = refCast<const fvMesh>
        nbrMesh
    ).boundary()[mpp.samplePolyPatch().index()];
    // Force recalculation of mapping and schedule
    const mapDistribute& distMap = mpp.map();
    tmp<scalarField> intFld = patchInternalField();
    const solidWallMixedTemperatureCoupledFvPatchScalarField& nbrField =
    refCast<const solidWallMixedTemperatureCoupledFvPatchScalarField>
        nbrPatch.lookupPatchField<volScalarField, scalar>
            neighbourFieldName_
        distMap.schedule(),
        nbrIntFld
        distMap.schedule(),
        nbrKDelta
    tmp<scalarField> myKDelta = K()*patch().deltaCoeffs();
    // Both sides agree on
    // - temperature : (myKDelta*fld + nbrKDelta*nbrFld)/(myKDelta+nbrKDelta)
    // - gradient    : (temperature-fld)*delta
    // We've got a degree of freedom in how to implement this in a mixed bc.
    // (what gradient, what fixedValue and mixing coefficient)
    // Two reasonable choices:
    // 1. specify above temperature on one side (preferentially the high side)
    //    and above gradient on the other. So this will switch between pure
    //    fixedvalue and pure fixedgradient
    // 2. specify gradient and temperature such that the equations are the
    //    same on both sides. This leads to the choice of
    //    - refGradient = zero gradient
    //    - refValue = neighbour value
    //    - mixFraction = nbrKDelta / (nbrKDelta + myKDelta())
    this->refValue() = nbrIntFld;
    this->refGrad() = 0.0;
    this->valueFraction() = nbrKDelta / (nbrKDelta + myKDelta());
    mixedFvPatchScalarField::updateCoeffs();
    if (debug)
        scalar Q = gSum(K()*patch().magSf()*snGrad());
        Info<< patch().boundaryMesh().mesh().name() << ':'
            << patch().name() << ':'
            << this->dimensionedInternalField().name() << " -> "
            << nbrMesh.name() << ':'
            << nbrPatch.name() << ':'
            << this->dimensionedInternalField().name() << " :"
            << " heatFlux:" << Q
            << " walltemperature "
            << " min:" << gMin(*this)
            << " max:" << gMax(*this)
            << " avg:" << gAverage(*this)
            << endl;
I know a way to interpolate variables (also on non-conformal meshes) in my top level code. I need to know the theory of this boundary condition, so I can do the coupling on my top level code.
Is conservation of heat flux enough in this situation? what about the temperature value at fluid-solid interface?
best wishes
regards
Daniel_Khazaei is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Opening Boundary Condition andreachan Main CFD Forum 11 March 19, 2013 17:46
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 02:54
Help with conjugate heat transfer and coupled boundary condition ravitejakatragadda FLUENT 1 March 12, 2011 08:31
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 01:55
